I am trying to recover some files from a WD external 250Gb drive, but fdisk -l and parted -l reports it as a 2,2Tb disk.
No partition is showing in testdisk. I attach some files, so someone may give me some help.
Reports.txt= parted -l ; fdisk -l ; lshw output.
some screenshots taken from testdisk & ddrecue.
Thanks in advance,
Mariano
ps: using ubuntu 12.04 64bits
incorrect size reported
- unknown partition
- unknown_partition_advanced_rebuild_bs.png (22.92 KiB) Viewed 3421 times
- intel advanced search
- intel_advanced.png (63.01 KiB) Viewed 3421 times
- intel_analyse2.png (39.85 KiB) Viewed 3421 times
Re: incorrect size reported
Unfortunately, it looks like a hardware problem. You will have to contact a data recovery specialist if you want to recover your data.
