Hi
I am on windows 7 , and itry to recover some .wav data on a raid 0 drive , with testdisk.
I try to restore some .wav on test disk , but the only file i have found that is possibble to recover is .wv !!!
Is it possible to recover some .wav data on a raid 0 drive , on windows 7 , with testdisk ?
Thank you
How do you restore .Wav format on raid 0 ?
Re: How do you restore .Wav format on raid 0 ?
If TestDisk displays your data, you can copy them.
Did you try PhotoRec too?
From your RAID0 is your array intact?
