Partition issues with 3TB drive - newbe
gdoran
Re: Partition issues with 3TB drive - newbe
#11 Post by gdoran »
Did the boot sector diag and rebuild. After rebooting, Disk Managemet still shows two partitions, unallocated.
Fri Oct 5 12:31:58 2012
Compilation date: 2012-09-01T21:55:20
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=3000256503808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=3000256503808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=3000256503808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000256503808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=308556070912
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2982248448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=3000120639488
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - ST3320413AS, S/N:2020202020202020202020205636584d53324833, FW:JC47
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364760 255 63, sector size=512 - BUFFALO HD-WLU3/R1 1, FW:0001
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 364760 255 63, sector size=512 - BUFFALO HD-WLU3/R1 2, FW:0001
Drive D: - 2982 MB / 2844 MiB - CHS 711 64 32, sector size=2048 - TSSTcorp DVD+-RW TS-H653H, FW:D800
Disk /dev/sdb - 3000 GB / 2794 GiB - BUFFALO HD-WLU3/R1 1
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5859875983 (expected 5859875983)
hdr_lba_start=34
hdr_lba_end=5859875950
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P MS Data 264192 5859874815 5859610624 [Basic data partition] [HD-WLU3]
ntfs_boot_sector
NTFS at 16/113/34
NTFS at 16/113/34
filesystem size 5859610624
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
mft at 16, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
mftmirr_lcn 2
5 dr-xr-xr-x 0 0 0 14-Sep-2012 13:24 .
5 dr-xr-xr-x 0 0 0 14-Sep-2012 13:24 ..
3312 dr-xr-xr-x 0 0 0 7-Sep-2012 17:15 $RECYCLE.BIN
40 dr-xr-xr-x 0 0 0 10-Sep-2012 11:53 August-2012-pt2
39 dr-xr-xr-x 0 0 0 7-Sep-2012 07:52 New Directory
7147 dr-xr-xr-x 0 0 0 20-Sep-2012 09:50 September-2012
36 dr-xr-xr-x 0 0 0 21-Sep-2012 16:55 System Volume Information
mftmirr_lcn 2
ntfs_boot_sector
NTFS at 16/113/34
NTFS at 16/113/34
mftmirr_lcn 2
Status: OK
Status: OK
gdoran
#12 Post by gdoran »
I went into Advanced, Type, Partiton type shows up as MS Data, NTFS. What should do next?
gdoran
#13 Post by gdoran »
I went into the Check MFT. It says MFT and MFT mirrow are bad. Failed to repair them.
dragonfly41
#14 Post by dragonfly41 »
Read last post here ...
http://forum.cgsecurity.org/phpBB3/file ... t1383.html
if testdisk can't repair MFT it is recommended on the testdisk wiki that you try commercial recovery software.
gdoran
#15 Post by gdoran »
Thank you for your advise. I am kinda curious though, I am able to list directory properly and files do seem to be accurate. Not many files on disk, just real big ones, around 470GB. Would you be able to give any light to the subject? FYI, in the Boot sector rebuild, itit shows Extrapolated boot sector and current bot sector are different.
dragonfly41
#16 Post by dragonfly41 »
Repeat advice .. try RecoverMyFiles in evaluation mode (no purchase)
Using commercial software in evaluation mode as suggested will not recover files (for free) but might give some clues on whether they can ever be recovered (with testdisk or other approach).
In the longer run it is quicker to do that early on rather than long debates in forums.
Gather your forensic evidence from multiple sources.
gdoran
#17 Post by gdoran »
RecoverMyFiles sees the drive out there, 1,584,789 ATAPI(SCSI) drive with no label. Also tried NTFS walker, didn't recognise it being NTFS.
gdoran
#18 Post by gdoran »
GPartD shows two partition device, one a Unknown file system, 128 Mib with msftres as flags and a seoncd partion, file system ntfs, 2.73 TB. the second partition is showsing a warning, .dev/sdb2 doesn't exist. Error 2" failed to check /dev/sdb2 mount state: No such file or direcgtory. Probaly /etc/mtab is missing, it's too risky to continue.
The first partition also shows up with a error. unble to detect the file system. Possible reasons are: File system is damaged. The file system is known to gpartd, there is no file system availabe, Teh device entry /dev/sdb1 is missing.
