Recovering RAID0
GeorgeIoak
Recovering RAID0
I had a RAID0 with 5 SSDs and 1 of the SSD dropped out. The system would not recognize the drive and after exchanging emails with SuperTalent I updated the firmware of the drive using their MP Tool. I have added the drive back into the array but of course the array is not accessible by Windows. My system is as follows:
Gigabyte EX58-EXTREME and I was running Win7 x64 Ultimate. The drives were connected to the Intel array on the MB.
When I use TestDisk it finds a bunch of what it thinks are Linux partitions and 1 corrupted FAT32 partition. I only had 1 partition in Windows (the boot C drive).
Before I wipe everything out and start over I am hoping that maybe I can retrieve some data using TestDisk. I had backups going to a server but it appears that those started failing a couple of months ago and I didn't realize that my machine was not getting backed up every night.
If I have any chance of extracting data please let me know or let me know that it is a total loss so I can start the rebuild process.
Thanks,
George
Thanks,
George
Re: Recovering RAID0
Do you have a working array now?
Might be possible to delete any broken array and recreate it.
But don't creaste any partition and don't format it.
If you reformat your array, you'll override your previous file system and you'd need datarecovery software to get your data back.
Also, your disks must be in sequential order like before and stripe size must match too.
If you have a working array, exactly rebuilded like before, you can use TestDisk to diagnose your array for lost partitions and your data.
How is your Array listed in your disk management console and TestDisk / Analyse (your current partition structur/table).
GeorgeIoak
Yes, the array is working. I only had the 1 drive drop out so no drives were moved around. I did re-create the array just exactly how it was before. I am booting the same system with another drive that has WinXP x64 running and it sees the array as unallocated.
I thought I had attached my testdisk log file to my original post but it doesn't show so I've attached it again. I have NOT made any changes or done any formatting and testdisk finds a bunch of what it thinks are Linux partitions.
- testdisk.zip
- Log Showing Multiple Linux Partitions
- (2.14 KiB) Downloaded 1221 times
GeorgeIoak
I was looking at this more today and here's what is displayed for my array:
I then installed TestDisk on another computer running Win7. It doesn't have a RAID Array but the structure looks like this:
If I wanted to try and get access to my file would I delete all of the false Linux partitions and change 2 of them to HPFS-NTFS like on this other computer? If so how do I know what values to use or does TestDisk take care of that?
Disk \\.\PhysicalDrive0 - 320 GB / 298 GiB
Analyse Disk \\.\PhysicalDrive0 - 320 GB / 298 GiB - CHS 38917 255 63
recover_EXT2: s_block_group_nr=0/29, s_mnt_count=51/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 952320
recover_EXT2: part_size 7618560
Linux 2582 38 17 3056 97 49 7618560
ext4 blocksize=4096 Large file Sparse superblock Recover, 3900 MB / 3720 MiB
recover_EXT2: s_block_group_nr=0/13, s_mnt_count=7/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 458240
recover_EXT2: part_size 3665920
Linux 4354 103 38 4582 152 50 3665920
ext4 blocksize=4096 Large file Sparse superblock Recover, 1876 MB / 1790 MiB
recover_EXT2: s_block_group_nr=0/463, s_mnt_count=16/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1024
recover_EXT2: s_blocks_count 3798528
recover_EXT2: part_size 7597056
Linux 7948 162 23 8421 135 34 7597056
ext4 blocksize=1024 Sparse superblock Recover, 3889 MB / 3709 MiB
BAD_RS LBA=214161408 8192
FAT32 LBA 13330 237 28 13338 17 55 114688
Linux 14149 125 57 14377 175 6 3665920
Linux 15407 26 44 15635 75 56 3665920
recover_EXT2: s_block_group_nr=0/118, s_mnt_count=60/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 3894016
recover_EXT2: part_size 31152128
Linux 16360 171 4 18299 204 17 31152128
ext4 blocksize=4096 Large file Sparse superblock Recover, 15 GB / 14 GiB
* Linux 2582 38 17 3056 97 49 7618560
P Linux 4354 103 38 4582 152 50 3665920
P Linux 7948 162 23 8421 151 50 7598080
ext4 blocksize=1024 Sparse superblock Recover, 3890 MB / 3710 MiB
L FAT32 LBA 13330 237 28 13338 17 55 114688
L Linux 14149 125 57 14377 175 6 3665920
L Linux 15407 26 44 15635 75 56 3665920
L Linux 16360 171 4 18299 204 17 31152128
Disk /dev/sda - 120 GB / 111 GiB - OCZ-AGILITY3
Analyse Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63
NTFS at 0/32/33
NTFS at 12/223/20
1 * HPFS - NTFS 0 32 33 12 223 19 204800 [System Reserved]
2 P HPFS - NTFS 12 223 20 14593 33 32 234231808
GeorgeIoak
Can I offer a reward to anyone who can help me? I can make a PayPal donation in return for your help. I'm not sure if I will be able to retrieve any files from this RAID but I want to try and rule out all options before I give up and delete the array.
dragonfly41
We reply to these threads because we've been in similar positions ourselves at various times and testdisk has helped us out of a hole ..
Having no personal experience of recovering RAID0 .. have you tried this ..
http://www.z-a-recovery.com/raid-recovery.htm
Dig around for other forensic approaches .. e.g. here ..
http://www.forensicfocus.com
http://www.forensicfocus.com/Forums/vie ... p=6545180/
GeorgeIoak
Thanks for pointing me to those other tools. I'll check into them. I've been fortunate enough over the years to not be in this position and I don't want to experiment on my array and really loose what's there. I'm still not sure if anything is left but I would hope since I had 5 drives int he array that my chances are possibly fair of finding some data.
GeorgeIoak
OK, well ZAR seems to provide at least a little hope. It does seem to find some directories and files but it's a big mess and I'm not sure what to do next. I'm certainly willing to pay for the software but I wonder if the results from the demo version can be useful for using testdisk?
dragonfly41
I've had good results using Recover My Files (much earlier version I purchased).
I see that the latest Recover My File Pro version offers RAID recovery.
Try evaluation of this ..
http://www.recovermyfiles.com/upgrade-v3-to-v4.php
[Later EDIT]
More links ..
http://www.runtime.org/raid.htm
http://spench.net/drupal/resources/raid0
[Later EDIT]
More links ..
GeorgeIoak
OK, I'll give that a try. ZAR did find a bunch of files but at first glance it looks like it cannot retrieve those files, only the names which of course is just teasing me to continue to dig deeper in hopes of getting something.
