Hi here's my current situation:
I have a notebook with dual boot: Win XP and Ubuntu.
I have an external Western Digital 2 TB USB hard disk with two 1-GB partitions: partition "Disco di backup" is a Linux 1 TB partition (where I have a filesystem and .JPG files that I want to recover) and "NTFS" partition is a 1 TB NTFS partition (obviously!!) where I do not have any files that I want to recover.
Partition "Disco di backup" was only visible by Ubuntu and not by Win XP.
At some point I wanted to create a bootable USB device for the new release of Ubuntu on my "NFTS" partition so I launched the Ubuntu "Startup disk creator" which prompted me to "Erase" the disk before installing the new release of Ubuntu. I thought that this command would erase only the "NTFS" partition and I launched it. After about 30 seconds I realized that the command was erasing all hard disk (i.e. both "Disco di backup" and "NTFS" partitions) and I stopped the program. I do not think that in those 30 seconds all my JPG files could be completely erased (they are GB of files).
After that, from Ubuntu I could only see the 2TB ext. USB HD as a single partition and no files (well, some unreadable files were present but they have names made up by symbols).
I launched testdisk and found somehow the "Disco di backup" partition and changed its status from D(eleted) to P(rimary). Now Ubuntu see the ext. USB HD as a 1TB partition but with the same unreadable files (no sign of either the Linux partition filesystem or the lost JPG files).
After that first run of testdisk, I run test disk again and again and here is the log file contents:
Tue Oct 9 15:10:55 2012
TestDisk 6.11, Data Recovery Utility, April 2009
OS: Linux, kernel 2.6.31-14-generic (#48-Ubuntu SMP Fri Oct 16 14:04:26 UTC 2009)
Compiler: GCC 4.4 - Jun 23 2009 17:11:34
ext2fs lib: 1.41.11, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: size 156301488 sectors
/dev/sda: user_max 156301488 sectors
/dev/sda: native_max 156301488 sectors
/dev/sda: dco 156301488 sectors
Disk /dev/sda - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512 - ATA FUJITSU MHV2080B
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WD Ext HDD 1021
Disk /dev/sdb - 2000 GB / 1863 GiB - WD Ext HDD 1021
No EXT2, JFS, Reiser, cramfs or XFS marker
1 P Linux 0 1 1 121575 254 63 1953118377
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243202 255 63
search_vista_part: 1
FAT32 at 0/1/1
FAT1 : 32-953429
FAT2 : 953430-1906827
start_rootdir : 1906828 root cluster : 2
Data : 1906828-3907023979
sectors : 3907024002
cluster_size : 32
no_of_cluster : 122034911 (2 - 122034912)
fat_length 953398 calculated 953398
FAT differs, FAT sectors=0-16/953398
FAT32 at 0/1/1
FAT32 LBA 0 1 1 243200 254 63 3907024002
FAT32, 2000 GB / 1863 GiB
* FAT32 LBA 0 1 1 243200 254 63 3907024002
1 * FAT32 LBA 0 1 1 243200 254 63 3907024002
FAT32 at 0/1/1
FAT1 : 32-953429
cluster_size : 32
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 32-953429
cluster_size : 32
FAT32 at 0/1/7
FAT found using backup sector!, 2000 GB / 1863 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/7450, s_mnt_count=5/31, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 244139797
recover_EXT2: part_size 1953118376
Linux 0 1 1 121575 254 62 1953118376 [Disco di backup]
EXT4 Large file Sparse superblock Backup superblock, 999 GB / 931 GiB
get_geometry_from_list_part_aux head=8 nbr=3
Linux 0 1 1 121575 254 63 1953118377 [Disco di backup]
1 P Linux 0 1 1 121575 254 63 1953118377 [Disco di backup]
write!
Need to fix
Now the problem is that after reboot, if I run testdisk again, the Linux partition is always D(eleted) and I go through the above process again and again without change in the status of the Linux partition and without getting to see any JGP lost files. I suppose the filesystem is corrupted, is that correct?
Problem is that I also run PhotoRec but it goes on forever (I let it run for 3 days) but the count of the analyzed cylinders sometimes decreases insted of always increasing so it will never reach the end and it recovered many .jpg files which were in the other (NTFS) partition.
My question: is there a way to restore the structure of the folders in the Linux partition (Disco di backup) and/or then to recover .JPG files from there?
Thanks a lot
Mattia
PS if needed I can attach screenshots of each step of testdisk and also a screenshot of which files I see now in the HD.
Filesystem repair after brief accidental erase by Ubuntu
Re: Filesystem repair after brief accidental erase by Ubuntu
Run TestDisk 6.14-WIP
In Advanced, select the Linux partition, Superblock and it will tell you wich fsck.ext4 command to use to repair the filesystem.
wget -N http://www.cgsecurity.org/testdisk-6.14-WIP.linux26.tar.bz2
tar xjf testdisk-6.14-WIP.linux26.tar.bz2
cd testdisk-6.14-WIP
sudo ./testdisk_staticRe: Filesystem repair after brief accidental erase by Ubuntu
Hi
thanks for help.
I followed your instructions but I get a list of 9 superblock with different number but all with same blocksize=4096.
Which one should I choose to repair the filesystem (see attached screenshot)?
Thanks again for support.
Mattia
thanks for help.
Mattia
- Screenshot.png (176.72 KiB) Viewed 12240 times
Hi
actually I get 10 superblocks: the one not showed in previous screenshot is first superblock 32768 blocksize=4096.
Thanks
Mattia
Thanks
Mattia
Dear Christophe
thank you for your support.
I tried to use the fsck.ext4 command with all 10 backup superblocks but I obtained always the same message (see attached screenshot).
The translation to english of the message written in italian in the screenshot is the following:
fsck.ext4: Bad magic number in super-block during the opening of /dev/sdb
/dev/sdb:
the super-block is unreadable, or it does not describe a correct filesystem ext2.
If the device is valid and it really contains a filesystem ext2 (and not swap, ufs or other), then the superblock is corrupted , and you could try to run e2fsck with an alternative superblock:
e2fsck -b 8193 <device>
I tried to run e2fsck -b 8193 /dev/sdb but I got the same message as above.
I then run fsck.ext4 with /dev/sdb1 (instead of sdb, because from another application it seemed to me that sdb1 could be the Linux partition) but I got a different message as you can see in the second attachment.
Now if a run testdisk_static I get listed the two corrected partitions (Linux, primary bootable, and NFTS, primary): in the NFTS I can list the files but in the Linux partitions I still get the message that the filesystem might be damaged.
Any suggestion on how to proceed?
If you help me recover my lost file, I will sure donate.
Thanks
Mattia
/dev/sdb:
Thanks
Mattia
- sdb1.jpg (34.39 KiB) Viewed 12214 times
- results_of_fsck-ext4.jpg (40.21 KiB) Viewed 12214 times
I also run PhotoRec and it recovers about 14000 (fourteen thousand) JPG files but none is of interest to me as they all are very small JPG files (in the order of 10-100 KB, whereas all my pictures were about 4-5 MB each) and they all look like JPG from web pages I visited during Internet browsing. Problem is, the HD from which they are recovered is an external USB disk used only for backup. So how is it possible that PhoteRec recovers those files?
Is it recovering from the correct device?
Thanks
Mattia
Thanks
Mattia
When using fsck, for the device, use /dev/sdb1, the devicename corresponding to the partition, instead of /dev/sdb.
