Dear Sir,
I am a PC user for domestic use using windows 7, windows xp and fedora linux OS in same PC. Accedentaly I have deleted a extended partition to replace fedora linux to ubuntu but as i deleted extended partition using disk management tool in win 7, my other partitions gte deleted automatically. I need my data back can i recover using testdisk? If yes can i get my data back partitionwise? and do I need another hard disk to collect recovered data or it can be collected in the same disk? Due to this event i am unable to boot PC with any of the OS and facing GRUB error. Does the recovery process will give my OS back? Kindly help me!!
Recovery of partition
Re: Recovery of partition
Always, if you delete an extended partition, it'll delete al logical partitions also.
Because an extended partition is a container of all logical partitions.
If you only deleted them and you didn't write anything to your disk anymore in thuis area, TestDisk should find your partitions.
Please run Quick and Deeper Search.
In your testdisk folder, you'll find a file called testdisk.
It's your testdisk.log.
Please open it and copy-paste the content.
If TestDisk finds partitions, please mark them and press p, to have a try to lsit your data.
Thanks for immediate and valuable guidance, however can I boot the PC using bootable CD of windows 7 and then run testdisk on the same harddisk? Kindly guide me may my questions will be very basic but i am afraid of loss of data with my small mistake.
Would it be possible to use a Live-CD?
http://www.cgsecurity.org/wiki/TestDisk_Livecd
CD's are read only.
That's why you cant't provide a testdisk.log.
Would it be possible to make some photos from your display in low resolution and upload them?
I'd need some infos from Analyse (your current partition table), Quick Search (first results of found partitions) and Deeper Search with additional search of Partitions using the backup of your boot sector.
CD's are read only.
Dear Fiona,
I have another option, I have another standby HDD of 80GB with windows 7 OS. So is it possible to run testdisk on that HDD ( win7 OS ) and recover the lost partitions of the main 500GB HDD? For that kindly elaborate the process need to be followed.
Waiting for your valuable guidance.
Dear Fiona,
I have one more doubt in my mind, when the recovery is successful are all my partition are visible in the same HDD as they were? or I have to collect the data in some other HDD or storage media?
Thanks in advance!
Thanks in advance!
Dear fiona,
kindly guide me because i am starting recovery and waiting for your valuable reply to proceed.
please! please!!
thanks.
please! please!!
thanks.
Dear fiona,
please! please!!
thanks.
please! please!!
thanks.
Pending input from Fiona (who perhaps is waiting for a testdisk.log from you) have you read this.
http://www.cgsecurity.org/wiki/DOS_BootDisk
Can you get hold of a USB flash drive to make a bootable version of testdisk on a USB flash?
Or do you have a USB container for your working 80 GB drive which could be interfaced to a working PC as USB drive?
Perhaps you can remove your 500 GB drive and replace it with your working 80 GB drive. Then it can be treated as an external drive (for now).
Do not attempt to install any software on your 500 GB drive with deleted partitions.
Dear Fiona,
Many many thanks, you are a GOD for me, I have successfully recovered my partitions with all my data. But there is still problem occured in opening one partition with error H: is not accessible, also still I am facing GRUB error I have win7, winXP and fedora OS installed on HDD and booting option was available through fedora but now facing GRUB problem. Second thing on startup automatic disk checking starts. Is it will create any problem or let it to check?
Now I am freezed and not understand what to do the next step, kindly help me to resolve the rest issue. As per your kind suggestion I am sending you the testdisk log file
Thank you once again for your valuable help and guide me further.
Tue Oct 16 22:32:25 2012
OS: Windows 7 (7600)
Compilation date: 2012-09-30T10:59:38
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=77877739520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2146765824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=4522508288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=50009670144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=99978246144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=99978246144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=100101625344
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=80015491584
Disk /dev/sda - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512 - ST380011A, S/N:4a354c5645435439202020202020202020202020, FW:8.01
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HDP725050GLA360, S/N:2020202020204547354134335652573033424154, FW:GM4OA5CA
Drive E: - 4522 MB / 4313 MiB - CHS 1078 64 32, sector size=2048 - HL-DT-ST DVDRAM GH24NS72, FW:WM01
Disk /dev/sdb - 500 GB / 465 GiB - Hitachi HDP725050GLA360
NTFS at 0/1/1
NTFS at 14592/1/1
NTFS at 24320/1/1
NTFS at 36475/1/1
NTFS at 48630/1/1
get_geometry_from_list_part_aux head=255 nbr=16
get_geometry_from_list_part_aux head=8 nbr=6
get_geometry_from_list_part_aux head=16 nbr=6
get_geometry_from_list_part_aux head=32 nbr=6
get_geometry_from_list_part_aux head=64 nbr=6
get_geometry_from_list_part_aux head=128 nbr=5
get_geometry_from_list_part_aux head=240 nbr=6
1 * HPFS - NTFS 0 1 1 6079 254 63 97675137
2 P Linux 11067 91 33 14591 250 59 56623104 [_Fedora-15-i686-]
3 P HPFS - NTFS 14592 1 1 24319 254 63 156280257 [BACKUP]
4 E extended LBA 24320 0 1 60800 254 63 586067265
5 L HPFS - NTFS 24320 1 1 36474 254 63 195270012
X extended 36475 0 1 48629 254 63 195270075
6 L HPFS - NTFS 36475 1 1 48629 254 63 195270012 [Entertainment]
X extended 48630 0 1 60799 254 63 195511050
7 L HPFS - NTFS 48630 1 1 60799 254 63 195510987 [DEVEN & TANU]
NTFS at 0/1/1
filesystem size 97675137
mftmirr_lcn 6104696
NTFS, blocksize=4096, 50 GB / 46 GiB
Error: size boot_sector 80113921 > partition 73007361
HPFS - NTFS 6080 1 1 10624 127 63 73007361
NTFS at 10624/156/29
filesystem size 7110656
mft_lcn 262144
mftmirr_lcn 2
HPFS - NTFS 10624 156 29 11067 58 63 7110656 [New Volume]
NTFS, blocksize=4096, 3640 MB / 3472 MiB
recover_EXT2: s_block_group_nr=0/216, s_mnt_count=39/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 7077888
recover_EXT2: part_size 56623104
ext4 blocksize=4096 Large file Sparse superblock, 28 GB / 27 GiB
NTFS at 14592/1/1
filesystem size 156280257
mftmirr_lcn 9767516
NTFS, blocksize=4096, 80 GB / 74 GiB
NTFS at 24320/1/1
filesystem size 195270012
mftmirr_lcn 12204375
NTFS, blocksize=4096, 99 GB / 93 GiB
NTFS at 36475/1/1
NTFS at 48630/1/1
filesystem size 195510987
mftmirr_lcn 12219436
NTFS, blocksize=4096, 100 GB / 93 GiB
file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(5,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(5,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,14,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(5,3,buffer,976775184(60801/113/1)) lseek err Invalid argument
file_pread(5,3,buffer,976775231(60801/113/48)) lseek err Invalid argument
file_pread(5,8,buffer,976775247(60801/114/1)) lseek err Invalid argument
file_pread(5,11,buffer,976775294(60801/114/48)) lseek err Invalid argument
file_pread(5,2,buffer,976777216(60801/145/17)) lseek err Invalid argument
get_geometry_from_list_part_aux head=255 nbr=11
get_geometry_from_list_part_aux head=8 nbr=7
get_geometry_from_list_part_aux head=16 nbr=7
get_geometry_from_list_part_aux head=32 nbr=7
get_geometry_from_list_part_aux head=64 nbr=7
get_geometry_from_list_part_aux head=128 nbr=4
HPFS - NTFS 6080 1 1 10624 254 63 73015362
add_ext_part_i386: max
NTFS at 0/1/1
mftmirr_lcn 6104696
NTFS at 6079/254/63
mftmirr_lcn 6104696
NTFS found using backup sector, blocksize=4096, 50 GB / 46 GiB
NTFS at 6080/1/1
filesystem size 80113921
mftmirr_lcn 8546576
HPFS - NTFS 1093 36 31 6080 1 1 80113921
NTFS found using backup sector, blocksize=4096, 41 GB / 38 GiB
NTFS at 6080/1/1
mftmirr_lcn 8546576
HPFS - NTFS 6080 1 1 11066 220 34 80113921
NTFS, blocksize=4096, 41 GB / 38 GiB
mft_lcn 262144
mftmirr_lcn 2
NTFS at 11067/58/63
mft_lcn 262144
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 3640 MB / 3472 MiB
recover_EXT2: s_block_group_nr=0/216, s_mnt_count=37/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 11312 64 17 14836 223 43 56623104 [_Fedora-15-i686-]
ext4 blocksize=4096 Large file Sparse superblock Recover, 28 GB / 27 GiB
recover_EXT2: s_block_group_nr=0/216, s_mnt_count=34/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 11314 9 24 14838 168 50 56623104 [_Fedora-15-i686-]
Linux 11316 117 2 14841 21 28 56623104 [_Fedora-15-i686-]
Linux 11317 122 6 14842 26 32 56623104 [_Fedora-15-i686-]
recover_EXT2: s_block_group_nr=0/216, s_mnt_count=33/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 11318 29 40 14842 189 3 56623104 [_Fedora-15-i686-]
Linux 11319 229 47 14844 134 10 56623104 [_Fedora-15-i686-]
Linux 11321 239 55 14846 144 18 56623104 [_Fedora-15-i686-]
Linux 11322 17 24 14846 176 50 56623104 [_Fedora-15-i686-]
recover_EXT2: s_block_group_nr=0/216, s_mnt_count=7/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 11327 75 13 14851 234 39 56623104 [_Fedora-15-i686-]
NTFS at 14591/185/58
filesystem size 63731712
mftmirr_lcn 2
HPFS - NTFS 10624 156 29 14591 185 58 63731712 [New Volume]
NTFS found using backup sector, blocksize=4096, 32 GB / 30 GiB
NTFS at 14591/218/27
filesystem size 63733760
mftmirr_lcn 2
HPFS - NTFS 10624 156 29 14591 218 27 63733760 [New Volume]
NTFS at 14591/254/63
filesystem size 136745217
mftmirr_lcn 8546576
HPFS - NTFS 6080 1 1 14591 254 63 136745217
NTFS found using backup sector, blocksize=4096, 70 GB / 65 GiB
NTFS at 14592/1/1
mftmirr_lcn 9767516
recover_EXT2: s_block_group_nr=0/2816, s_mnt_count=5/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 92279296
recover_EXT2: part_size 738234368
Linux 14592 28 29 60545 19 18 738234368
ext4 blocksize=4096 Large file Sparse superblock, 377 GB / 352 GiB
NTFS at 24319/254/63
mftmirr_lcn 9767516
NTFS found using backup sector, blocksize=4096, 80 GB / 74 GiB
NTFS at 24320/1/1
NTFS at 36474/254/63
NTFS found using backup sector, blocksize=4096, 99 GB / 93 GiB
NTFS at 36475/1/1
recover_EXT2: s_block_group_nr=0/2816, s_mnt_count=3/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 37584 37 22 83537 28 11 738234368
ext4 blocksize=4096 Large file Sparse superblock Recover, 377 GB / 352 GiB
This partition ends after the disk limits. (start=603789312, size=738234368, end=1342023679, disk end=976773168)
recover_EXT2: s_block_group_nr=0/2816, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 37593 115 27 83546 106 16 738234368
This partition ends after the disk limits. (start=603938816, size=738234368, end=1342173183, disk end=976773168)
Linux 37593 180 28 83546 171 17 738234368
This partition ends after the disk limits. (start=603942912, size=738234368, end=1342177279, disk end=976773168)
Linux 37594 185 32 83547 176 21 738234368
This partition ends after the disk limits. (start=603959296, size=738234368, end=1342193663, disk end=976773168)
Linux 37596 0 37 83548 246 26 738234368
This partition ends after the disk limits. (start=603979776, size=738234368, end=1342214143, disk end=976773168)
Linux 37597 38 10 83550 28 62 738234368
This partition ends after the disk limits. (start=603998208, size=738234368, end=1342232575, disk end=976773168)
Linux 37597 233 13 83550 224 2 738234368
This partition ends after the disk limits. (start=604010496, size=738234368, end=1342244863, disk end=976773168)
NTFS at 48629/254/63
NTFS at 48630/1/1
Linux Swap 60545 51 51 60801 47 30 4112368
SWAP2 version 1, pagesize=4096, 2105 MB / 2007 MiB
NTFS at 60799/254/63
NTFS found using backup sector, blocksize=4096, 100 GB / 93 GiB
file_pread(5,2,buffer,976773167(60801/80/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,976773168(60801/81/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,976773200(60801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773200(60801/81/33)) lseek err Invalid argument
file_pread(5,8,buffer,976773376(60801/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,976773504(60801/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,976773632(60801/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,976773760(60801/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,976773888(60801/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,976774016(60801/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,976774144(60801/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,976774272(60801/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,976774400(60801/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,976774528(60801/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,976774656(60801/104/40)) lseek err Invalid argument
file_pread(5,8,buffer,976774784(60801/106/42)) lseek err Invalid argument
file_pread(5,8,buffer,976774912(60801/108/44)) lseek err Invalid argument
file_pread(5,8,buffer,976775040(60801/110/46)) lseek err Invalid argument
file_pread(5,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
The harddisk (500 GB / 465 GiB) seems too small! (< 687 GB / 640 GiB)
get_geometry_from_list_part_aux head=255 nbr=14
get_geometry_from_list_part_aux head=8 nbr=10
get_geometry_from_list_part_aux head=16 nbr=10
get_geometry_from_list_part_aux head=32 nbr=10
get_geometry_from_list_part_aux head=64 nbr=10
get_geometry_from_list_part_aux head=240 nbr=9
HPFS - NTFS 6080 1 1 11066 254 63 80116092
Linux Swap 60545 51 51 60801 47 46 4112384
SWAP2 version 1, pagesize=4096, 2105 MB / 2008 MiB
Please help
NTFS at 0/1/1
NTFS at 14592/1/1
NTFS at 24320/1/1
NTFS at 36475/1/1
NTFS at 48630/1/1
NTFS at 0/1/1
mftmirr_lcn 6104696
mft_lcn 262144
mftmirr_lcn 2
NTFS at 14592/1/1
mftmirr_lcn 9767516
NTFS at 24320/1/1
NTFS at 36475/1/1
NTFS at 48630/1/1
NTFS at 0/1/1
mftmirr_lcn 6104696
NTFS at 6079/254/63
mftmirr_lcn 6104696
NTFS at 6080/1/1
mftmirr_lcn 8546576
NTFS at 6080/1/1
mftmirr_lcn 8546576
mft_lcn 262144
mftmirr_lcn 2
NTFS at 11067/58/63
mft_lcn 262144
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 8546576
NTFS at 14592/1/1
mftmirr_lcn 9767516
mftmirr_lcn 9767516
NTFS at 24320/1/1
NTFS at 36475/1/1
NTFS at 48630/1/1
Please help
