I installed Linux on the ext harddrive. In in the Ubuntu installation wizard they asked for what file system I should install linux on. I played around and pressed the "-" sign when I had my ext hard drive selected. That made the file system change to "nothing" (or similar word). My guess is that the partition was removed?!
Then I created a new partition at the end of the disk and installed linux.
Now the original partition is gone. How do I recover the old partition? In particular the files on that partition?
I used TestDisk and searched the harddrive and found the new Linux partition, but no trace of the old one.
Then I did a deep search and found some stuff but they cant be recovered.
See pic: http://screencast.com/t/KQ6Cw9CJ
Thanks! // Thomas
Log-file:
Thu Oct 25 09:22:56 2012
Compilation date: 2012-10-21T19:37:35
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=249225543680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2048
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST925041 0AS, S/N:V5CG53HZ, FW:D005
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - SAMSUNG HD103UJ, S/N:1SP3DJSW476562, FW:1AA0
Drive D: - 2048 B - CHS 1 64 32, sector size=2048 - TSSTcorp DVD+-RW TS-U633J, S/N:7R12G6BU275006, FW:D600
Disk /dev/sdb - 1000 GB / 931 GiB - SAMSUNG HD103UJ
1 * Linux 120993 100 4 121601 57 56 9764864
recover_EXT2: s_block_group_nr=0/37, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8032
recover_EXT2: s_blocks_count 1220608
recover_EXT2: part_size 9764864
ext4 blocksize=4096 Large file Sparse superblock Recover, 4999 MB / 4768 MiB
file_pread(5,2,buffer,1953525767(121601/90/33)) lseek err Invalid argument
file_pread(5,1,buffer,1953525767(121601/90/33)) lseek err Invalid argument
file_pread(5,2,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,1,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,2,buffer,1953525830(121601/91/33)) lseek err Invalid argument
file_pread(5,1,buffer,1953525830(121601/91/33)) lseek err Invalid argument
file_pread(5,8,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1953525248(121601/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1953525376(121601/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1953525504(121601/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1953525632(121601/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525768(121601/90/34)) lseek err Invalid argument
file_pread(5,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(5,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(5,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(5,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
