Photorec Hang
Adamnemurigenesis
Photorec Hang
#1 Post by Adamnemurigenesis »
Hi, I just used photorec to try recover data from my 1TB Samsung M2 HDD. At the recovery page, it hangs at a set number of files as shown in the picture enclosed.
Is this normal or has there been a problem?
Adamnemurigenesis
Re: Photorec Hang
#2 Post by Adamnemurigenesis »
Photorec is running as normal, but it slowed down considerably, and now it says 3000+ hours remaining. Is this normal behavior?
Re: Photorec Hang
#3 Post by cgrenier »
If the disk contains a lot of bad sectors, data recovery may slow to a crawl
You may want to clone the disk to a new empty one with ddrescue as described in http://www.cgsecurity.org/wiki/Damaged_Hard_Disk and next run PhotoRec on the clone.
