Partition cant be recovered - disk is too small
romeo51
#1 Post by romeo51 »
I need help...i cant recover my partition..i think my drive geometry is wrong? is cylindernumber right? i dont know how to calculate it. thanks in advance!
log:
Sun Nov 4 21:34:58 2012
TestDisk 6.12, Data Recovery Utility, May 2011
OS: Linux, kernel 3.0.0-pmagic (#1 SMP Fri Jul 29 19:06:18 CDT 2011) i686
Compiler: GCC 4.5
Compilation date: 2011-05-15T12:36:01
ext2fs lib: 1.41.14, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: LBA, HPA, DCO support
/dev/sda: size 240121728 sectors
/dev/sda: user_max 240121728 sectors
/dev/sda: native_max 240121728 sectors
/dev/sda: dco 240121728 sectors
Disk /dev/sda - 122 GB / 114 GiB - CHS 14946 255 63, sector size=512 - ATA Maxtor 6Y120P0
Disk /dev/sdb - 7811 MB / 7450 MiB - CHS 1021 241 62, sector size=512 - Intenso Premium Line
Disk /dev/sda - 122 GB / 114 GiB - ATA Maxtor 6Y120P0
Analyse Disk /dev/sda - 122 GB / 114 GiB - CHS 14946 255 63
NTFS at 0/1/1
NTFS at 10199/1/1
1 * HPFS - NTFS 0 1 1 10198 254 63 163846872
2 E ext
ed LBA 10199 0 1 14944 254 63 76244490
5 L HPFS - NTFS 10199 1 1 14944 254 63 76244427
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sda - 122 GB / 114 GiB - CHS 14947 255 63
search_vista_part: 1
NTFS at 0/1/1
filesystem size 163846872
mftmirr_lcn 10240429
NTFS, 83 GB / 78 GiB
NTFS at 10199/1/1
filesystem size 76244427
mftmirr_lcn 4765276
NTFS, 39 GB / 36 GiB
2 E extended LBA 10199 0 1 14944 254 63 76244490
Record 0 has no FILE magic (0x45084946)
NTFS at 0/1/1
BAD_RS LBA=227257710 13865046
HPFS - NTFS 14146 35 16 180651 222 57 2674914648
This partition ends after the disk limits. (start=227257710, size=2674914648, end=2902172357, disk end=240123555)
NTFS at 10198/254/63
NTFS found using backup sector!, 83 GB / 78 GiB
NTFS at 10199/1/1
mftmirr_lcn 4765276
NTFS at 14944/254/63
mftmirr_lcn 4765276
NTFS found using backup sector!, 39 GB / 36 GiB
The harddisk (122 GB / 114 GiB) seems too small! (< 1485 GB / 1383 GiB)
dir_partition inode=0
Change partition type:
write_all_log_i386: CHS: 10199/0/1,lba=163846935
Analyse Disk /dev/sda - 122 GB / 114 GiB - CHS 14947 255 63
NTFS at 0/1/1
NTFS at 10199/1/1
search_vista_part: 0
NTFS at 0/1/1
NTFS at 10199/1/1
mftmirr_lcn 4765276
NTFS at 0/1/1
NTFS at 10199/1/1
NTFS at 0/1/1
NTFS at 10199/1/1
mftmirr_lcn 4765276
1 E extended LBA 10199 0 1 14944 254 63 76244490
NTFS at 0/1/1
NTFS at 10199/1/1
NTFS at 0/1/1
NTFS at 10199/1/1
mftmirr_lcn 4765276
NTFS at 0/1/1
NTFS at 10199/1/1
mftmirr_lcn 4765276
mftmirr_lcn 4765276
NTFS at 0/1/1
NTFS at 10199/1/1
NTFS at 0/1/1
NTFS at 10199/1/1
mftmirr_lcn 4765276
NTFS at 0/1/1
NTFS at 10199/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
NTFS at 0/1/1
NTFS at 10199/1/1
NTFS at 0/1/1
NTFS at 10199/1/1
mftmirr_lcn 4765276
NTFS at 0/1/1
NTFS at 10199/1/1
