tricky situation
ahmedmah
tricky situation
#1 Post by ahmedmah »
Hi there
I have this tricky situation here
Note: the the structure in the pictures
Please advice i need to recover all the pointed out partitions in the pictures this is so important
Thanks in advance
Re: tricky situation
What are the results if you set align partition to none in Options ?
ahmedmah
#3 Post by ahmedmah »
testing
is it possible to edit the option after the deep search finch?
can i go back without losing the results
thanks
