please help me:File is missing
gengstergile
#1 Post by gengstergile »
Hello,yesterdayi try to recover my corrupted disk,and then i dont remember what i did,the file inside my 'C' is missing and all left only 1 folder perflog.
if i am not mistaken,i choose analyse>quicksearch>write.
and the my file inside that partition is all gone,how do i recover it back because in testdisk undelete,it said that there is no deleted files. please help me,there is very important files on tht partition. :(
here is my log files,
Mon Dec  3 19:05:02 2012
OS: Windows 7 (7600)
Compilation date: 2012-11-23T18:11:40
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=160041885184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=160041885184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=125724262400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=374276620288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=367001600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=80015523840
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=79646687232
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000BEKT-75KA9T0, S/N:2020202057202d44585731383841353032303735, FW:01.01A01
Disk /dev/sdc - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - WDC WD16 00BEVT-22ZCT0
Disk /dev/sdc - 160 GB / 149 GiB - WDC WD16 00BEVT-22ZCT0
Analyse Disk /dev/sdc - 160 GB / 149 GiB - CHS 19457 255 63
NTFS at 0/32/33
heads/cylinder 4 (NTFS) != 255 (HD)
NTFS at 44/190/19
NTFS at 9728/0/1
file_pread(5,4096,buffer,162571776(10119/159/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,162571832(10119/160/18)) ReadFile Data error (cyclic redundancy check).
NTFS: Can't read MFT
Warning: number of heads/cylinder mismatches 4 (NTFS) != 255 (HD)
 1 * HPFS - NTFS              0  32 33    44 190 18     716800 [System Reserved]
 2 P HPFS - NTFS             44 190 19  9727 230 39  155559936 [Windows 8]
 3 P HPFS - NTFS           9728   0  1 19455 254 63  156280320
NTFS at 0/32/33
filesystem size           716800
sectors_per_cluster       8
mft_lcn                   29866
mftmirr_lcn               2
clusters_per_mft_record   -10
     NTFS, blocksize=4096, 367 MB / 350 MiB
NTFS at 44/190/19
filesystem size           155559936
mftmirr_lcn               2
     NTFS, blocksize=4096, 79 GB / 74 GiB
NTFS at 9728/0/1
filesystem size           156280320
mftmirr_lcn               2
     NTFS, blocksize=4096, 80 GB / 74 GiB
file_pread(5,2,buffer,312582144(19457/86/22)) lseek err Invalid argument
file_pread(5,1,buffer,312582144(19457/86/22)) lseek err Invalid argument
file_pread(5,15,buffer,312582145(19457/86/23)) lseek err Invalid argument
file_pread(5,3,buffer,312582160(19457/86/38)) lseek err Invalid argument
file_pread(5,3,buffer,312582207(19457/87/22)) lseek err Invalid argument
file_pread(5,8,buffer,312582223(19457/87/38)) lseek err Invalid argument
file_pread(5,11,buffer,312582270(19457/88/22)) lseek err Invalid argument
file_pread(5,2,buffer,312584192(19457/118/54)) lseek err Invalid argument
pread: Input/Output error
Failed to calculate number of free MFTs: Input/Output error.
NTFS at 0/32/33
NTFS at 44/190/19
NTFS at 9728/0/1
file_pread(5,16,buffer,7195200(447/224/34)) ReadFile Incorrect function.
file_pread(5,1,buffer,7195200(447/224/34)) ReadFile Data error (cyclic redundancy check).
dir_partition inode=5
ntfs_readdir failed
       5 dr-xr-xr-x     0      0         0  1-Dec-2012 23:39 .
       5 dr-xr-xr-x     0      0         0  1-Dec-2012 23:39 ..
      60 dr-xr-xr-x     0      0         0 26-Jul-2012 15:33 PerfLogs
NTFS at 0/32/33
NTFS at 44/190/19
NTFS at 9728/0/1
NTFS at 0/32/33
mft_lcn                   29866
mftmirr_lcn               2
NTFS at 44/190/19
mftmirr_lcn               2
NTFS at 9728/0/1
mftmirr_lcn               2
thank you
Re: please help me:File is missing
There are CRC errors due to bad sectors. You should clone your HD to a new empty one as described in
Once it's done, remove the dmaaged disk and try to access/repair the clone.
