I've run testdisk as per below,
Once it's done with the quick search it tells me that the hard disk seems too small etc, as seen below,
I then finished a deeper search but with the same problem, it'll simply tell me that no partition is bootable, any ideas? - If the partition can't be fixed is there any way for me to recover the files from the disk while maintaining file names and folder structure?
