Background: With the intention of being able to watch our family movies and photos on our Smart blu-ray player I plugged my USB HDD into a Smart blu-ray/freeview recorder box, the HDD clunked three times (as though it was being switched on then off again quickly), then under the USB HDD options I selected some options to add the drive the Smart blu-ray box. Followed by the HDD clunking three more times. Using the Smart blu-ray file browser I saw no files at all!
So I then plugged the HDD back into my PC, as the clunks didnt sound healthy and no data was showing using the Smart blu-ray browser, the drive is not seen by the OS (Win7). I ran the partition tool in the OS in case the drive had died and it says Disk9 needs to be initialized, I cancelled that and then ran testdisk.
Following the instructions online testdisk sees my drive but when selecting [Intel] then [Analyse] but nothing is found. I assume this is because the Smart Blu-Ray has deleted the partition or formatted the drive?
I retried using [None] then [Analyse] and the image below is of the results after a 18hour scan and the log file.
I see it says to check the jumper & BIOS settings but the drive is connected via a USB dock and is a SATA drive. It also says several partitions cannot be recovered.
There was over 200gb or family movies and photos (including our daughters first Christmas this year and 5 years of my own amateur photography work) and my girlfriend is going to go crazy, I mean ... CRAZY if I've just lost the lot.
Should I re-initialze the disk in windows try and run data recovery on the HDD ... if so what free/cheap program would be best? Or is there anything else I can do?
Wed Dec 26 19:34:58 2012
TestDisk 6.14-WIP, Data Recovery Utility, December 2012
Compiler: GCC 4.7, MinGW 3.11
Compilation date: Dec 23 2012 19:10:25
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=80026361856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=500107862016
filewin32_getfilesize(\\.\PhysicalDrive8) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\PhysicalDrive8) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\PhysicalDrive8
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive9)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119926685696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=500000882688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500105740288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500105740288
Disk \\.\PhysicalDrive0 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 500 GB / 465 GiB - CHS 516811 135 14, sector size=512
Disk \\.\PhysicalDrive3 - 120 GB / 111 GiB - CHS 124043 135 14, sector size=512
Disk \\.\PhysicalDrive4 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive9 - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Drive C: - 119 GB / 111 GiB - CHS 123932 135 14, sector size=512
Drive D: - 500 GB / 465 GiB - CHS 516700 135 14, sector size=512
Drive E: - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Partition table type: None
Analyse Disk \\.\PhysicalDrive9 - 250 GB / 232 GiB - CHS 30401 255 63
P Unknown 0 0 1 30401 80 63 488397168
HFS magic value at 573/144/35
part_size 1191066002
HFS 573 144 35 74713 254 6 1191066002 [)}ݖ]
HFS blocksize=31981568, 609 GB / 567 GiB
This partition ends after the disk limits. (start=9214351, size=1191066002, end=1200280352, disk end=488397168)
WBFS 694 148 14 1209 163 25 8274432
WBFS, 4236 MB / 4040 MiB
LVM magic value at 6976/139/2
LVM magic value at 8256/111/58
Sys=0C 12311 0 15 143696 56 48 2110703587
FATX, 1080 GB / 1006 GiB
This partition ends after the disk limits. (start=197776229, size=2110703587, end=2308479815, disk end=488397168)
HFS magic value at 20560/32/49
part_size 1273250242
HFS 20560 32 49 99816 74 4 1273250242 [ ^Š €Â ø¤”HØ„ à ’ß§ <MlåqÙº]
HFS blocksize=188622336, 651 GB / 607 GiB
This partition ends after the disk limits. (start=330298464, size=1273250242, end=1603548705, disk end=488397168)
recover_JFS: s_blocksize=1909021088
recover_JFS: s_size 1351209726
recover_JFS: s_fsckpxd.len:13254558
recover_JFS: s_logpxd.len:16713189
recover_JFS: part_size 874478324
JFS 21883 56 19 3439525695 81 28 12130019310533364
JFS 34001217, blocksize=1909021088, 6210569 TB / 5648480 TiB
This partition ends after the disk limits. (start=351553941, size=874478324, end=1226032265, disk end=488397168)
JFS 23992 244 34 3439527805 14 43 12130019310533364
This partition ends after the disk limits. (start=385446885, size=874478324, end=1259925209, disk end=488397168)
NTFS at 30401/42/41
filesystem size 488392704
mftmirr_lcn 2
NTFS: Can't read MFT
NTFS 30401 42 41 60802 52 49 488392704
NTFS, blocksize=4096, 250 GB / 232 GiB
This partition ends after the disk limits. (start=488394751, size=488392704, end=976787454, disk end=488397168)
file_win32_pread(108,11,buffer,488397160(30401/80/56)) read err: read after end of file
file_win32_pread(108,11,buffer,488397165(30401/80/61)) read err: read after end of file
file_win32_pread(108,8,buffer,488397161(30401/80/57)) read err: read after end of file
file_win32_pread(108,3,buffer,488397167(30401/80/63)) read err: read after end of file
file_win32_pread(108,8,buffer,488397165(30401/80/61)) read err: read after end of file
file_win32_pread(108,16,buffer,488397155(30401/80/51)) read err: read after end of file
file_win32_pread(108,16,buffer,488397158(30401/80/54)) read err: read after end of file
file_win32_pread(108,16,buffer,488397161(30401/80/57)) read err: read after end of file
file_win32_pread(108,16,buffer,488397164(30401/80/60)) read err: read after end of file
file_win32_pread(108,16,buffer,488397167(30401/80/63)) read err: read after end of file
The harddisk (250 GB / 232 GiB) seems too small! (< 6210570 TB / 5648480 TiB)
J
