I am having 'WD Elements' of 1 tb, using for more than a year, without any problem.
Suddenly, it stopped working, yesterday. USB detects it, but MyComputer doesn't show Drive Letter. And Disk Management shows as 'Not Initialized'.
'Data Lifeguard Diagnostic' (diagnosis s/w) from WD, says Pass for Quick Test.
When tried with 'testdisk-6.13', it complaints for 'Read Error' for each cyl read, following is the log.
I am having Vista Enterprise (SP2).
My WD came pre-formatted, most probably NTFS.
Appreciate the help, as HDD contains efforts of 4-5 years.
Sat Mar 17 10:39:47 2012
OS: Windows Vista (6002) SP2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=151448977408
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\S:)=8589934592
file_pread(4,1,buffer,312592769(19457/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,1953520064(121600/254/63)) lseek err Invalid argument
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ST916041 2AS, S/N:V51GFM1A, FW:0006
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512 - WD Elements 1023, S/N:WXH0AC9H7564, FW:2005
Disk /dev/sdb - 1000 GB / 931 GiB - WD Elements 1023
Analyse Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121600 255 63
Partition: Read error
Ask the user for vista mode
file_pread(5,1,buffer,1953504000(121600/0/1)) read err: Invalid argument
search_vista_part: 1
file_pread(5,8,buffer,32(0/0/33)) read err: Invalid argument
file_pread(5,8,buffer,40(0/0/41)) read err: Invalid argument
file_pread(5,3,buffer,48(0/0/49)) read err: Invalid argument
file_pread(5,3,buffer,95(0/1/33)) read err: Invalid argument
file_pread(5,8,buffer,111(0/1/49)) read err: Invalid argument
file_pread(5,11,buffer,158(0/2/33)) read err: Invalid argument
file_pread(5,2,buffer,2080(0/33/2)) read err: Invalid argument
file_pread(5,2,buffer,51(0/0/52)) read err: Invalid argument
file_pread(5,2,buffer,98(0/1/36)) read err: Invalid argument
file_pread(5,2,buffer,119(0/1/57)) read err: Invalid argument
file_pread(5,2,buffer,169(0/2/44)) read err: Invalid argument
file_pread(5,2,buffer,2082(0/33/4)) read err: Invalid argument
file_pread(5,8,buffer,63(0/1/1)) read err: Invalid argument
file_pread(5,8,buffer,71(0/1/9)) read err: Invalid argument
file_pread(5,3,buffer,79(0/1/17)) read err: Invalid argument
file_pread(5,3,buffer,126(0/2/1)) read err: Invalid argument
file_pread(5,8,buffer,142(0/2/17)) read err: Invalid argument
file_pread(5,11,buffer,189(0/3/1)) read err: Invalid argument
file_pread(5,2,buffer,2111(0/33/33)) read err: Invalid argument
file_pread(5,8,buffer,1008(0/16/1)) read err: Invalid argument
file_pread(5,8,buffer,1016(0/16/9)) read err: Invalid argument
file_pread(5,3,buffer,1024(0/16/17)) read err: Invalid argument
file_pread(5,3,buffer,1071(0/17/1)) read err: Invalid argument
file_pread(5,8,buffer,1087(0/17/17)) read err: Invalid argument
file_pread(5,11,buffer,1134(0/18/1)) read err: Invalid argument
file_pread(5,2,buffer,3056(0/48/33)) read err: Invalid argument
file_pread(5,5,buffer,1074(0/17/4)) read err: Invalid argument
file_pread(5,2,buffer,394060433(24529/32/33)) read err: Invalid argument
file_pread(5,1,buffer,0(0/0/1)) read err: Invalid argument
Store new MBR code
WD Err 'Not Initialized'
Re: WD Err 'Not Initialized'
Using a disk in windows since W2k, it must be initialised.
Windows writes a signatur of 4 bytes into your partition table/MBR.
I've experienced problems recover data in windows if disk was not initialized.
Even other data recovery software was not able to.
Your case looks like that you only get read errors.
Probably you're not even able to initialize your disk.
First try might be to get rid of errors.
Can you remove it from your enclosure and check it internally?
First, Thanks Very Much, Fiona!
To get better idea about the problem,
(a) is it a connection problem?
(b) or anything has corrupted the MBR, (i.e. Virus)?
(c) any other option?
By the way, removing HDD from its case will void warranty?
I really need the data, I will surely proceed with your suggestion.
If you remove your disk from its case will void warranty!
Nobody can judge your problem exactly.
That's why a diagnose might be important to figure it out.
Until yet, there are read errors.
I've no idea how many?
Mostly, external disks are FAT32 preformatted.
NTFS formatted?
Do they need a permission or license from Microsoft?
We've got some cases of external disks, which were encrypted.
Like in my post here;
http://forum.cgsecurity.org/phpBB3/repa ... .html#p814
Would it be possible in your case also?
I cant't answer this question.or anything has corrupted the MBR, (i.e. Virus)?
Are you sure?My WD came pre-formatted, most probably NTFS.
NTFS formatted?
Thanks Fiona, the help is very much appreciated!
I'm not sure about NTFS/FAT, I do recon is it wasn't formatted by me, when I started with it.
With respect to Encryption, there isn't any explicit, from my-side. How can I check, if it is factory configured (h/w or s/w)?
Currently I'm at client's place for couple of days, I'll proceed with removing the case, on my return. Will update you with the progress.
Thanks Million!
Take Care.
Warm Regards.
Thanks Million!
Take Care.
Warm Regards.
Hi Fiona,
I tried finding appropriate connector for the HDD, I mean after removing the case. But no luck!
Anyways, I have dropped idea of Recovery, as I got some of the data stored somewhere else.
Now the problem is I am not able to format it.
Disk Management says "The Media is write protected", after the first window "Initialize Disk" (i.e. Partition Style).
Does it mean the disk is dead?
