Recently I wanted to install XBMC on a SD Card (for my Raspberry Pi), followed the Instructions where was mentioned that the device letter is /dev/sdb usually. Usually, i have a look on the mount points but in this situation i just wanted to do it fast. It was an automated script which wipes everything on the disk including the partition table (?) to install the xbmc distribution. As I noticed afterwards, my external HDD was mounted at /dev/sdb and the SD card at /dev/sdd.
That means a massive data loss.
TestDisk didn't find any partitions (as I expected because of the overwritten table).
So what can I do? Before it was NTFS, now it's splitted in a System Partition (FAT) which has a size of 124mb and a Data Partition that takes the whole other space (1TB HDD)
Thank you in advance, Phil
Overwritten Partition Table
Re: Overwritten Partition Table
How is your disk listed in your disk management console.
Since W2k windows requires a signatur from 4 Bytes to handle it.
Please let me know, is your disk initialized in your disk management console.
If it's not initialized, please initialize it and run Deeper Search in TestDisk.
Please use TestDisk 6.14WIP and the 32 bit version.
hehe, well I'm not the only one that stupid then, as i did the same.
Also a sdb when it should have been a sdd.
My hdd is a 3tb, so its was set up as a GPT disk , and formatted as NTFS. I then did the same as TS.
I first did the quicksearch in testdisk under linux, and it found the system partition of 124 mb created by Openelec.
It also found very easy a 3 tb partition (my old ntfs partition).
I was able to do a file list within testdisk and take a backup of data not backed up yet.
So the data seems to be fine.
i then tried to do the "write" command (the 3tb partition found had a P in front of it (primary part.))
But it seems like its not 100 % working as the 124mb partition still is there, and when trying to boot up,
the Pc hangs at the boot before even trying to get in to the bios.
I unplug the 3tb, as it is not an OS disk, i can then boot fine into the Pc. I plug the 3 tb to the pc after booting.
I am now under windows 7, where the disk management gives me this info for the HD:
129 mb unallocated
2048 gb RAW healthy (active, primary partition)
746,39 gb unallocated
so my question is, is it possible to recreate the old partition, as openelec only did a 127 mb write to the Hd after making changes to the partiotion table. I dodnt know if and how i should delete the 127 mb partition.
Im trying deeper search now, where its says this now:
check_FAT: unusual number of reserved sectors 4 (fat), should be 1.
It also give me a size error for the "old" partition in the LOG file now, see below
Latest Log from testdisk after i tried to write the partition
129 mb unallocated
Sun Jan 6 09:31:18 2013
TestDisk 6.14-WIP, Data Recovery Utility, December 2012
Compiler: GCC 4.6, Cygwin 1007.17
Compilation date: 2012-12-29T10:02:51
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=75385274368
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2199023255040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1529856
Disk /dev/sda - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512 - INTEL SSDSA2CW080G3, S/N:564352503031353832305a50383042304e472020, FW:4PC10362
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - ST3000DM001-9YN166, S/N:202020202020202020202020315a304639573039, FW:CC4B
Drive E: - 1529 KB / 1494 KiB - CHS 1 64 32, sector size=2048 - DTSOFT BDROM, FW:1.05
Disk /dev/sdb - 3000 GB / 2794 GiB - ST3000DM001-9YN166
NTFS at 16/113/34
Error: size boot_sector 1565300736 > partition 4294967295
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 16 113 34 267365 202 36 4294967295
FAT16 at 0/32/33
check_FAT: Unusual number of reserved sectors 4 (FAT), should be 1.
FAT1 : 4-255
FAT2 : 256-507
start_rootdir : 508
Data : 540-255999
sectors : 256000
cluster_size : 4
no_of_cluster : 63865 (2 - 63866)
fat_length 252 calculated 250
FAT16 at 0/32/33
FAT16 >32M 0 32 33 16 15 63 256000 [System]
FAT16, blocksize=2048, 131 MB / 125 MiB
NTFS at 16/113/34
filesystem size 5860268032
mftmirr_lcn 2
HPFS - NTFS 16 113 34 364801 66 1 5860268032 [HD45_seagate_3TB]
file_pread(5,2,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(5,1,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(5,2,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(5,2,buffer,1565567039(364801/99/34)) lseek err Invalid argument
file_pread(5,2,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(5,8,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,1565565952(364801/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,1565566080(364801/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,1565566208(364801/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,1565566336(364801/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,1565566464(364801/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,1565566592(364801/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,1565566720(364801/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,1565566848(364801/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,1565566984(364801/98/42)) lseek err Invalid argument
file_pread(5,3,buffer,1565566992(364801/98/50)) lseek err Invalid argument
file_pread(5,3,buffer,1565567039(364801/99/34)) lseek err Invalid argument
file_pread(5,8,buffer,1565567055(364801/99/50)) lseek err Invalid argument
file_pread(5,11,buffer,1565567102(364801/100/34)) lseek err Invalid argument
file_pread(5,2,buffer,1565569024(364801/131/3)) lseek err Invalid argument
* FAT16 >32M 0 32 33 16 15 63 256000 [System]
P HPFS - NTFS 16 113 34 364801 66 1 5860268032 [HD45_seagate_3TB]
1 * FAT16 >32M 0 32 33 16 15 63 256000 [System]
2 P HPFS - NTFS 16 113 34 364801 66 1 5860268032 [HD45_seagate_3TB]
edit reason : double post
- testdis_capture.JPG (55.73 KiB) Viewed 6443 times
sorry, found a solution my self.
Would you mind sharing your own solution? Thanks!muggi wrote:sorry, found a solution my self.
Yes! I would be very thankful for this solution. I don't actually remember if it was msdos or GUID Partition Table.
