Problem recovering Partitions
Sleepy
#1 Post by Sleepy »
I was using Fat32Formatter to format an external HD and accidentally formatted my main drive :oops:
I can change the partition characteristics from D to P but as soon as I mark both of them as P (only options available are *, P or D) the Structure changes from OK to Bad.
Unfortunately, my Windows install is on the first partition (C) and all my photos are on (D) and have no backup thanks to a reckless decision to re-use my backup drive for something else in the short-term.
TestDisk 6.14-WIP, Data Recovery Utility, December 2012
Disk /dev/sdb - 160 GB / 149 GiB - CHS 19457 255 63
 * HPFS - NTFS              0   1  1   783 254 63   12594897 [RECOVERY]
 P HPFS - NTFS            784   0  1  4706 254 63   63022995
>P HPFS - NTFS           4706   0 31 19457  21 20  236976128
Structure: Bad. Use Up/Down Arrow keys to select partition.
     Enter: to continue
Re: Problem recovering Partitions
Looks like, that your third partition has changed and is not intel standard anymore.
It uses the same space/cylinder 4706 like your C:-partition.
Did you list your data from your third partition?
Did you run Deeper Search?
Sleepy
#3 Post by Sleepy »
Thanks for the reply Fiona.
I can list data on the third partition without any problems (and have saved off the photos to another drive).
Running a deeper search doesn't make much difference to the result.
Any suggestions? Is there a way to recover D? Or should I just count myself lucky that I can save off the photos, restore the C:\ partition and, if that boots ok, create a new partition to copy the contents of D:\ back into?
