First time user; I have been trying to find someone who had posted an exact match of my situation, but, because this disk is the only place I have my kids' pictures and videos on, I don't want to fark it all up. (I had them on two drives, but I had to reformat one while I was upgrading software and reinstalling the operating system...unfortunately for me, my backup hard drive thought this would be a perfect time to go RAW on me.)
The log file is below. I have tried to write twice already with no luck. I have just started a deeper search, but it is going to take over two hours if it continues at the same speed it seems to be going. I will post the log of this afterwards.
Please tell me what to do to get this thing to behave normally again. Thank you in advance if you can help me:
Thu Jan 17 21:02:23 2013
TestDisk 6.14-WIP, Data Recovery Utility, December 2012
Compiler: GCC 4.6, Cygwin 1007.17
Compilation date: 2013-01-06T21:07:12
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=160000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=160000000000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=154972500480
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4976262144
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2134900736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=120023253504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=1000202241024
Disk /dev/sda - 160 GB / 149 GiB - CHS 19452 255 63, sector size=512 - ST3160812AS, S/N:2020202020202020202020204c34345353453750, FW:3.ADH
Disk /dev/sdb - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - SanDisk SDSSDX120GG25, S/N:3231313130383034303036302020202020202020, FW:R112
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Hitachi HDS721010CLA332, S/N:801130168383
Drive E: - 2134 MB / 2036 MiB - CHS 509 64 32, sector size=2048 - ATAPI DVD A DH24ABL, FW:GX12
Disk /dev/sdc - 1000 GB / 931 GiB - Hitachi HDS721010CLA332
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 0/1/1
1 * HPFS - NTFS 0 1 1 121600 254 63 1953520002 [SimpleDrive]
NTFS at 0/1/1
filesystem size 1953520002
mftmirr_lcn 122095000
file_pread(6,2,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,1,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,8,buffer,1953525183(121601/81/16)) lseek err Invalid argument
file_pread(6,1,buffer,1953525183(121601/81/16)) lseek err Invalid argument
file_pread(6,8,buffer,1953525311(121601/83/18)) lseek err Invalid argument
file_pread(6,8,buffer,1953525439(121601/85/20)) lseek err Invalid argument
file_pread(6,8,buffer,1953525567(121601/87/22)) lseek err Invalid argument
file_pread(6,8,buffer,1953525695(121601/89/24)) lseek err Invalid argument
file_pread(6,16,buffer,1953525760(121601/90/26)) lseek err Invalid argument
file_pread(6,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(6,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(6,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(6,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(6,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
write!
SOLVED - RAW, No Partition Found or Selected for Recovery
Re: RAW, No Partition Found or Selected for Recovery
Disregard, problem has been solved. Can't figure out how to delete this post, otherwise I would. Running Chkdsk repair ended up doing the trick.
