Data recovery from toshiba HDD
amruth05
#1 Post by amruth05 »
I had a toshiba 2.5" usb 3.0 external hard drive which faced some connection issues and i transferred the hard disk inside it to another external casing. the hard drive worked properly before the transplant, but after it when plugged into my windows 7 pro laptop it showed the " format drive F: before using " error message and when i looked under device management i saw that the partition had been changed to RAW .
after this i analyzed using testdisk and this was the result :
Fri Feb 8 18:30:47 2013
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=251553382400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=248447500288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=124925520384
file_pread(4,1,buffer,976784129(60801/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,1953536129(121601/254/63)) lseek err Invalid argument
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - HITACHI HTS545050B9A300, S/N:3031373038324250344e33303731574847524535, FW:PB4ZC61H
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA MK1059GSM, FW:GU00
Disk /dev/sdb - 1000 GB / 931 GiB - TOSHIBA MK1059GSM
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 0 1 1 15187 254 63 243995157
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121602 255 63
search_vista_part: 1
BAD_RS LBA=3772973304 12208332
file_pread(5,1,buffer,3772973304(234856/185/10)) lseek err Invalid argument
HPFS - NTFS 234856 185 10 460385 32 3 3623113740
This partition ends after the disk limits. (start=3772973304, size=3623113740, end=3101119747, disk end=1953536130)
file_pread(5,7,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,8,buffer,1953525768(121601/90/34)) lseek err Invalid argument
file_pread(5,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(5,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(5,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(5,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 3786 GB / 3526 GiB)
Not an exFAT boot sector.
how do i fix this drive as i BADLY want the data in it. and it is URGENT . i would be very very grateful from the bottom of my heart if i can get this drive back with the data in it. Thanks a lot in advance
