Recover data in unallocated partitions
Bill
#1 Post by Bill »
Seems like this questions has been asked over and over but I do not get the results using TestDisk.
Disk Management shows the following:
Volume - (E:), Layout - Simple, Type - Basic, File System - FAT, Status - Healthy(Active, Primary Partition),
Capacity - 2MB .....
In the middle it shows the layout of the drive as follows:
Disk 1, Basic, 465.76 GB online and lays out the drive as follows:
40.93 GB (E:) 424.83 GB
Unallocated 2 MB Unallocated
Healthy
Running Analyze on E using both Quick Search and Deeper Search will only show the contents of the 2 MB partition.
How can I recover the data that is in both the unallocated partitions on e:?
Your help is sincerely appreciated!
Bill
Re: Recover data in unallocated partitions
Use PhotoRec on the disk, not on a drive letter. Use 'a' to manually add a fictive partition corresponding to the sectors you want to scan.
