I really need some help trying to recover pst files from a clicking drive. I've tried EaseUS and a few other programs with no luck. On most programs I can retrieve the files but I cannot import them into Outlook or in the case of Word docs, Word cannot open them.
So here I am trying Testdisk as a last resort. Is there anyway to recover these pst files? They are extremely important.
Need help recovering .pst files
stryker412
- Capture2.PNG (60.17 KiB) Viewed 8214 times
Re: Need help recovering .pst files
Hello Stryker,
with Photorec you can recover files.
After Selection of the Drive you should go in the [File Opt].
Then you should deselect all filetypes with "s" and select only "pst".
Then you make a scan.
Bye
keloglan
Bye
keloglan
adomwatson
I would like to suggest you to try Kernel for Outlook PST Repair tool to repair your damaged pst file successfully.
