Maybe I can get some of you big brains out there to share some advice
ok, so here's what I had, when it worked:
640GB Harddisk(596.xx usable) in a Dell XPS notebook, dual boot Win7x64 and Ubuntu 12.04
5 partitions:
1) Dell diag partition 102Mb
2) Windows Recovery Primary, Active, 14.65GB
3) Windows OS, Primary, 354.95GB
4) Linux, Primary, 220.56GB
5) Linux Swap, 5.92GB
It came with Win7x64, and I loaded Ubuntu on it...I believe GRUB2 is loaded into the Recovery Partition, since that is the one that was Active.
I have some Acronis backups, but I am struggling to get them restore...this am, I was half asleep and blew away away the 1st 3 partitions
I have done NOTHING else to the disk...I have booted from a Ubuntu 12.04 USB stick, and loaded TestDisk static on it..
I ran the deep discovery with TestDisk 6.14-WIP, and it's saying scary things:
TestDisk 6.14-WIP, Data Recovery Utility, December 2012
Disk /dev/sda - 640 GB / 596 GiB - CHS 77825 255 63
D FAT16 >32M 0 1 1 12 254 63 208782 [DellUtility]
P FAT32 5 0 1 656 254 63 10474380 [OS]
* FAT16 >32M 12 223 20 267 214 11 4096000 [FREEDOS]
D HPFS - NTFS 13 0 1 1925 254 63 30732345 [RECOVERY]
D HPFS - NTFS 1925 59 4 48260 193 19 744380233 [OS]
>D Linux 48260 197 2 77052 251 63 462546944
D HPFS - NTFS 75530 119 46 77697 202 9 34818048
D Linux Swap 77053 29 33 77825 70 5 12404736
D FAT32 LBA 77697 202 10 77825 37 36 2045952 [GM6C]
Structure: Bad. Use Up/Down Arrow keys to select partition.
Enter: to continue
ext4 blocksize=4096 Large file Sparse superblock, 236 GB / 220 GiB
Before the deep discovery I DID play around trying to get the partitions the correct type, but I have not written anything to the disk.
Where did these extra partitions come from? Before I do anything else, does anyone have any advice for me?
thanks for any advice in advance
