Can you diagnose the bootsector from that Microsoft reserved partition?
It's actually your boot partition.
Start TestDisk.
Confirm through until you see the menu Analyse.
Select your MS Reserved Partition
Confirm at Boot with enter.
Rebuild BS will be in progress.
Infos will follow.
Unable to boot from Raid0 setup
Re: Unable to boot from Raid0 setup
It does not show boot on the MS reserve partition but shows on MS data partition
If it doesn't show Boot, means, that your partition has no file system or not recognized.
In case, go to Type and add it manually.
The Boot will be available.
Would I choose MS reserve as the type or something else?
Choose your partition MS reserved.
Check Type and press enter.
Choose NTFS and hit enter also.
So Boot should be available.
After I clicked boot
After I hit list
After I hit list
Looks like, that you chosed EFI System instead of MS Reserved?
I chose MS Reserved, but when I chose NTFS from the types it showed EFI System
Sorry my mistake. After I chose type when MS Reserved highlighted it showed this
I clicked MS reserved from above image then showed this and clicked NTFS
After I hit NTFS showed this
Can you check Boot.
I'd need a screenshot.
And in Case rebuild your boot sector again.
But only if both are bad.
Your boot sector and its backup.
