Hey guys,
I have a Lacie 1TB external USB hard drive consisting of 2x500gb samsungs inside. When I tried to connect it to the computer windows was asking for it to be formatted. I got hold of a commercial program and managed to pull off my main documents and photos. However I still have around 400GB of data on it which I could do with. I don't have enough space on my PC to copy it all over as I have copied around 200GB already.
I don't think there is a problem with the filesystem and think it may be to do with the boot sector. Is it possible to repair the boot sector/partition using testdisk? I have read some tutorials but none that tackle my one since I have 2x500gbs in raid 0. Any help on how to get windows to recognise the drive normally would be much appreciated. Thank you.
Windows requires format but can access data.
Re: Windows requires format but can access data.
Boot sector could be repaired.
I'd need infos from testdisk analyse to judge it.
You can copy and paste the content of the testdisk.log or upload a screen from TestDisk / Analyse.
Hi Fiona thank you for the reply/ I have done an analyse and attached the info here:
Sat Mar 2 10:56:31 2013
TestDisk 6.14-WIP, Data Recovery Utility, December 2012
OS: Windows XP SP3
Compilation date: 2013-02-11T11:20:27
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=160041885696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdg)=1000215724032
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=160041885696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=1000215724032
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=152546042880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=160031015424
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=7484972544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000210466304
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\J:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\J:) SetFilePointer err Incorrect function.
filewin32_getfilesize(\\.\L:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\L:) SetFilePointer err Incorrect function.
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - WDC WD1600BB-00GUA0, S/N:4457572d414d394c303232323332 038 0 0 0 0, FW:08.02D08
Disk /dev/sdb - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ST3160021A, S/N:4a34305339585250202020202020202020202020, FW:8.11
Disk /dev/sdg - 1000 GB / 931 GiB - CHS 121602 255 63, sector size=512 - SAMSUNG HD501LJ
Disk /dev/sdg - 1000 GB / 931 GiB - SAMSUNG HD501LJ
Analyse Disk /dev/sdg - 1000 GB / 931 GiB - CHS 121602 255 63
NTFS at 0/1/1
1 P HPFS - NTFS 0 1 1 121601 254 63 1953536067 [LaCie]
NTFS at 0/1/1
filesystem size 1953536067
mftmirr_lcn 122096004
file_pread(6,11,buffer,1953546366(121602/162/31)) lseek err Invalid argument
file_pread(6,1,buffer,1953546366(121602/162/31)) lseek err Invalid argument
file_pread(6,2,buffer,1953548288(121602/192/63)) lseek err Invalid argument
file_pread(6,14,buffer,1953548290(121602/193/2)) lseek err Invalid argument
file_pread(6,3,buffer,1953548304(121602/193/16)) lseek err Invalid argument
file_pread(6,3,buffer,1953548351(121602/193/63)) lseek err Invalid argument
file_pread(6,8,buffer,1953548367(121602/194/16)) lseek err Invalid argument
file_pread(6,11,buffer,1953548414(121602/194/63)) lseek err Invalid argument
file_pread(6,2,buffer,1953550336(121602/225/32)) lseek err Invalid argument
* HPFS - NTFS 0 1 1 121601 254 63 1953536067 [LaCie]
1 * HPFS - NTFS 0 1 1 121601 254 63 1953536067 [LaCie]
NTFS at 0/1/1
Confirm at Boot.
Please let me know, did you see your data or an error message.
Infos will follow.
Confirm at Boot.
Infos will follow.
Hi this is the log:
After I done the rebuild I was able to etner List and it showed something weird which I have attatched.
The drive is still not able to be accessed through windows
Sat Mar 2 20:03:07 2013
OS: Windows XP SP3
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1000215724032
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1000215724032
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121602 255 63, sector size=512 - SAMSUNG HD501LJ
Disk /dev/sdc - 1000 GB / 931 GiB - SAMSUNG HD501LJ
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
Sectors are identical.
OS: Windows XP SP3
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
- List.JPG (42.74 KiB) Viewed 4078 times
- Post BS.JPG (45.37 KiB) Viewed 4078 times
Extrapolated and current boot secotor are identical indicates that your file system is damaged.
A safe solution might be datarecovery software.
PhotoRec can help, but it doesn't keep file names and directories.
In case you could test a trial of commercial software to check your files, file names and directories.
Chddsk is a utility to have a try to repair a file system but it's not intended to recover data.
