[ ] txt Other text files: txt,html,asp,bat,C,jsp,perl,php,py/emlx... scripts
[ ] tz Timezone info
[ ] v2i v2i backup
[ ] vault McAfee Anti-Theft/FileVault
...Code: Select all
[ ] tx? Text files with header: rtf,xml,xhtml,mbox/imm,pm,ram,reg,sh,slk,stp,jad,urlRight now I'm looking at running a "cleanup" script in another window, but there must be a better way:
:top
sweep32 del /q *.h*
@REM -- ping is used to insert a 1 second delay
ping -n 2 127.0.0.1 >nul
sweep32 del /q *.j*
sweep32 del /q *.x*
sweep32 del /q *.m*
sweep32 del /q *.s*
sweep32 del /q *.r*
sweep32 del /q *.a*
sweep32 del /q *.p*
goto top
