Long story short: using Ubuntu's "startup disk creator" I chose my external hard drive instead of my pen drive and accidentally erased everything on it (for what I understand it simply rewrote the partition table info so that files were no longer accessible).
Using the deep analyze from Testdisk I got this output:
Disk /dev/sdc - 999 GB / 930 GiB - CHS 121516 255 63
The harddisk (999 GB / 930 GiB) seems too small! (< 2722 GB / 2535 GiB)
> FAT32 LBA 120921 13 50 330958 136 6 3374252111Code: Select all
Disk /dev/sdc - 2730 GB / 2543 GiB - CHS 332000 255 63
>* FAT32 LBA 0 1 1 121514 254 63 1952138412Code: Select all
Fri Mar 15 20:37:33 2013
OS: Linux, kernel 3.2.0-38-generic (#61-Ubuntu SMP Tue Feb 19 12:20:02 UTC 2013) i686
Compiler: GCC 4.6
Compilation date: 2012-02-05T07:16:54
ext2fs lib: 1.42, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: LBA, LBA48, DCO support
/dev/sda: size 156301488 sectors
/dev/sda: user_max 156301488 sectors
/dev/sdb: size 976773168 sectors
/dev/sdb: user_max 976773168 sectors
/dev/sdb: native_max 976773168 sectors
/dev/sr0 is not an ATA disk
Disk /dev/sda - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512 - WDC WD800JD-60LSA0, S/N:WD-WMAM9T010126, FW:07.01D07
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - SAMSUNG HD501LJ, S/N:S0MUJ1DPB09726, FW:CR100-12
Disk /dev/sdc - 999 GB / 930 GiB - CHS 121515 255 63, sector size=512 - WD My Passport 070A, FW:1030
Disk /dev/sdd - 300 GB / 279 GiB - CHS 36481 255 63, sector size=512 - SAMSUNG HD300LD, FW:WK10
Disk /dev/sr0 - 7784 MB / 7423 MiB - CHS 3801056 1 1 (RO), sector size=2048 - HL-DT-ST DVDRAM GSA-H12L, S/N:K136AK44816, FW:VL01
Disk /dev/sr1 - 700 MB / 668 MiB - CHS 342016 1 1 (RO), sector size=2048 - WD Virtual CD 070A, FW:1030
Disk /dev/sdc - 999 GB / 930 GiB - WD My Passport 070A
New geometry
Disk /dev/sdc - 2730 GB / 2543 GiB - CHS 332000 255 63 sector_size=512
Analyse Disk /dev/sdc - 2730 GB / 2543 GiB - CHS 332000 255 63
FAT32 at 0/1/1
Info: size boot_sector 1952138412, partition 1952138412
FAT1 : 32-476415
FAT2 : 476416-952799
start_rootdir : 952800 root cluster : 2
Data : 952800-1952138399
sectors : 1952138412
cluster_size : 32
no_of_cluster : 60974550 (2 - 60974551)
fat_length 476384 calculated 476364
1 * FAT32 LBA 0 1 1 121514 254 63 1952138412
Ask the user for vista mode
search_vista_part: 0
FAT32 at 0/1/1
FAT1 : 32-476415
cluster_size : 32
FAT32 at 0/1/1
FAT32, 999 GB / 930 GiB
FAT32 at 0/1/1
FAT1 : 32-476415
cluster_size : 32
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 32-476415
cluster_size : 32
FAT32 at 0/1/7
FAT found using backup sector!, 999 GB / 930 GiB
