Files found but cannot write partition
Kilroy1218
#1 Post by Kilroy1218 »
I'm trying to recover a 1 TB seagate drive with only a single NTFS partition on it. Currently I am able to quick search the drive and find the partition, view the files on it, and set it to the primary partition; however, when I go to write the fixed partition table I receive the error "Partition: write error"
My log with a quick run through of what I just described is attached with some file names removed for privacy.
Tue Mar 19 12:32:07 2013
TestDisk 6.14-WIP, Data Recovery Utility, March 2013
Compilation date: 2013-03-10T16:32:17
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000097185792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\S:)=1500299265024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Y:)=1000202043392
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST310005 24AS, S/N:9VPC9CM4, FW:JC45
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 02FAEX-00Y9A0, S/N:WD-WCAW30516047, FW:05.0
Disk /dev/sdc - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - Samsung STORY Station P, S/N:00000011E09310B00B13
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - ST1000DM 003-9YN162, S/N:152D20337A0C
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - ST1000DM 003-9YN162, S/N:152D20337A0C
Drive E: - 1000 GB / 931 GiB - CHS 15200 255 63, sector size=4096 - ST1000DM 003-9YN162, S/N:152D20337A0C
Disk /dev/sdd - 1000 GB / 931 GiB - ST1000DM 003-9YN162
Analyse Disk /dev/sdd - 1000 GB / 931 GiB - CHS 15200 255 63
NTFS at 0/4/5
Info: size boot_sector 1953519616, partition 244189952
 1 P HPFS - NTFS              0   4  5 15200  35  3  244189952 [SeagateStorage]
NTFS at 0/4/5
filesystem size           1953519616
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
file_pread(7,1,buffer,244190720(15200/43/12)) lseek err Invalid argument
file_pread(7,1,buffer,244190656(15200/42/11)) lseek err Invalid argument
file_pread(7,1,buffer,244190672(15200/42/27)) lseek err Invalid argument
file_pread(7,1,buffer,244190688(15200/42/43)) lseek err Invalid argument
file_pread(7,1,buffer,244190704(15200/42/59)) lseek err Invalid argument
file_pread(7,1,buffer,244190721(15200/43/13)) lseek err Invalid argument
file_pread(7,1,buffer,244190722(15200/43/14)) lseek err Invalid argument
file_pread(7,2,buffer,244190727(15200/43/19)) lseek err Invalid argument
file_pread(7,2,buffer,244190729(15200/43/21)) lseek err Invalid argument
file_pread(7,3,buffer,244190735(15200/43/27)) lseek err Invalid argument
file_pread(7,1,buffer,244190976(15200/47/16)) lseek err Invalid argument
   * HPFS - NTFS              0   4  5 15200  35  3  244189952 [SeagateStorage]
dir_partition inode=5
       5 dr-xr-xr-x     0      0         0 13-Mar-2013 20:50 .
       5 dr-xr-xr-x     0      0         0 13-Mar-2013 20:50 ..
    1229 dr-xr-xr-x     0      0         0 17-Nov-2012 18:59 $AVG
      37 dr-xr-xr-x     0      0         0 19-Aug-2012 19:55 $RECYCLE.BIN
    1278 dr-xr-xr-x     0      0         0 16-Jan-2013 01:20 New folder
    2249 dr-xr-xr-x     0      0         0 26-Feb-2013 17:21 OS ISOs
    2250 dr-xr-xr-x     0      0         0 28-Feb-2013 02:24 Raspberry PI
     254 dr-xr-xr-x     0      0         0 31-Aug-2012 19:45 Slender_v0_9_6
     253 -r--r--r--     0      0  60881354 31-Aug-2012 19:44 Slender_v0_9_6.zip
     253 -r--r--r--     0      0        26 31-Aug-2012 19:44 Slender_v0_9_6.zip:Zone.Identifier
      35 dr-xr-xr-x     0      0         0  2-Aug-2012 20:32 System Volume Information
dir_partition inode=1278
Directory /New folder
    1278 dr-xr-xr-x     0      0         0 16-Jan-2013 01:20 .
    1592 dr-xr-xr-x     0      0         0 16-Jan-2013 01:19 .fseventsd
    1596 dr-xr-xr-x     0      0         0  6-May-2012 11:57 .Trashes
    1597 dr-xr-xr-x     0      0         0 16-Jan-2013 01:19 345 Lab
    1930 dr-xr-xr-x     0      0         0 16-Jan-2013 01:20 Programs
    2032 -r--r--r--     0      0  13588236 20-Apr-2011 22:15 satellite p300.pdf
    2032 -r--r--r--     0      0        26 20-Apr-2011 22:15 satellite p300.pdf:Zone.Identifier
    1989 dr-xr-xr-x     0      0         0 16-Jan-2013 01:20 Slender_v0_9_6
    1284 dr-xr-xr-x     0      0         0  2-Dec-2012 19:04 Xbox360
Thanks in advance for your help
