iomega samsung 1Tb USB Drive Pin broken ... became RAW drive
Amirji
#1 Post by Amirji »
Dear All,
My iomega 1TB usb drive cable pin broke from enclosure circuit,
Inside samsung 3.5 drive with model HM100UI was safe.
I bought new case of WD Elements 2.5 drive and now windows is showing RAW drive,
So testdisk start like this
http://imgur.com/rvaUXuw
Then find nothing in normal search but deep search showed me two drives ... but no "P" sign to list files.
only R-Studio showed me correctly my three partitions and the data is fully intact.
http://imgur.com/zGcHyer
http://imgur.com/XLrS8lm
Data is huge on 1Tb and I have this backup in different places which will be headache to again copy,
Is there any way I can fix Partition table with testdisk.
Any help will be appreciated.
dmde
http://imgur.com/JuhhLCF
