PhotoRec: XML Parsing Error
KeithN
#1 Post by KeithN »
XML Parsing Error: no element found
Location: file:///F:/Nec%20Email%20Rec/recup_dir.1/report.xml
Line Number 44, Column 1:
I am attempting to Copy the "pst" files from a HDD i am replacing. Nothing is copied but I do receive this xml message. Do you have any suggestions as to how I may work around this problem.
Kind regards,
KeithN
Re: PhotoRec: XML Parsing Error
report.xml is a file created by PhotoRec, but if you are written about copying a file, you are using TestDisk.
Please use latest 6.14-WIP version and tell me the results when you try to copy the file.
