So its not letting me recover the partition because of this. I think something got messed up in the partition and the cylinder/head/sector numbers are messed up. I was going to add a new partition with the correct numbers but im not to sure what they should be set to.
I would like to try and get this drive working again with all the data on it if possible.
Near the end of the Deepscan
Results of the Deepscan
Log
Sun Mar 25 14:33:52 2012
TestDisk 6.14-WIP, Data Recovery Utility, March 2012
OS: Windows 7 (7600) SP1
Compilation date: 2012-03-25T21:26:26
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500000882688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4486856704
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500104691712
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20 EADS-11R6B1, S/N:WD-WCAVY2803441, FW:80.0
Disk /dev/sdb - 500 GB / 465 GiB - CHS 64601 240 63, sector size=512 - WDC WD50 01AALS-00L3B, S/N:WD-WCASY7108225, FW:01.0
Disk /dev/sdc - 500 GB / 465 GiB - CHS 64601 240 63, sector size=512 - WDC WD50 01AALS-00L3B, S/N:WD-WCASY7109602, FW:01.0
Drive D: - 4486 MB / 4279 MiB - CHS 1069 64 32, sector size=2048 - SONY DVD RW DRU-810A, FW:1.0f
Disk /dev/sda - 2000 GB / 1863 GiB - WDC WD20 EADS-11R6B1
Analyse Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63
Ask the user for vista mode
search_vista_part: 0
BAD_RS LBA=4284259852 10385787
file_pread(4,1,buffer,4284259852(266682/214/41)) lseek err Invalid argument
HPFS - NTFS 266682 214 41 298893 89 48 517461848
This partition ends after the disk limits. (start=4284259852, size=517461848, end=506754403, disk end=3907029168)
The harddisk (2000 GB / 1863 GiB) seems too small! (< 2458 GB / 2289 GiB)
file_pread(4,2,buffer,3907039377(243201/243/4)) lseek err Invalid argument
file_pread(4,1,buffer,3907039377(243201/243/4)) lseek err Invalid argument
file_pread(4,2,buffer,3907039440(243201/244/4)) lseek err Invalid argument
file_pread(4,2,buffer,3907039503(243201/245/4)) lseek err Invalid argument
file_pread(4,1,buffer,3907040129(243201/254/63)) lseek err Invalid argument
file_pread(4,1,buffer,3907040130(243202/0/1)) lseek err Invalid argument
