Help recovering drive
muffinman
#1 Post by muffinman »
Hi guys,
Hoping you can help me out with recovering a drive.
I've attached a log file.
Essentially in windows it's coming up as RAW type. When I run testdisk, it can see the old partition, and the files in it. when I write the partition info, and reboot the computer, it just stays as RAW. I'm not sure if I'm missing a step here somewhere. maybe I'm setting it as the wrong type of partition?
I hope the attached logfile helps? If anyone can please help, and let me know what I can do to recover all the files, that'd be greatly appreciated!
Thanks,
muffinman
Re: Help recovering drive
If a partition appears as RAW indicates, either a faulty boot sector or a damaged file system.
Your partition is available because it appears as RAW.
Another opportunity could be that your partition in your partition table doesn't match.
Diagnose would be, to have a try to repair your boot sector.
But before, a screen shot of your current partition structur would be appreciated.
It's your screen if you confirm at analyse in TestDisk.
If you'd like to, you can copy and paste the content of your testdisk.log.
You'lll find it in your testdisk folder.
Gil42
#3 Post by Gil42 »
Fiona,
I think me, this guy and some other people I've seen in this forum have the same problem: we write the new partition structure, but nothing happens! Replies are always toward the problem itself (disk shown as RAW, etc) and not towards the fact that TestDisk changed nothing on the drive.
I think we are missing some step, like if you tell TeskDisk to write new partition structure, it only schedules changes but doesn't do anything. Due to the fact that it asks to reboot the computer, I'm led to believe it will only make the changes on next startup. Maybe because it's a removable drive, it won't be there anymore on next startup. Or maybe it's a bug on TestDisk that should be closer looked at.
Well, I don't know, I just think that TestDisk is not doing anything on several cases on this forum, and am hoping that someone will give us a light on this subject.
Lito
#4 Post by Lito »
May be i am wrong, but the step people seem to miss is:
if you cannot see the files that your trying to save don't Write to the disk.
If you can see your data, the structure and files you recognize, save them first
to a different disk. The rest of operations revolve around getting the right Diagnostic and for that
we all need some sort of help from the TestDisk team members because of their expertise.
With a bit of luck people get around to read the instructions and get on with rebuilding, be it the Boot Sector,
the File Table or whatever. Must not expect miracles though. After you Write might be you should expect to go back to TestDisk and check if the job is finished, ie.: you can see your data, not go looking through Windows to find the disk.
One thing you have to remember is that you came to TestDisk to solve a problem that Windows either created or could not solve. Whilst this is not true for everyone, it is for a lot of cases if you look through the posts in the forum.
Gil42
#5 Post by Gil42 »
Thanks for the reply, here are some comments:
Lito wrote:May be i am wrong, but the step people seem to miss is:
Did that... I could see the files and backed them up as much as I had other free storage to. Then I told TestDisk to write the new partition structure.
Lito wrote:After you Write might be you should expect to go back to TestDisk and check if the job is finished, ie.: you can see your data, not go looking through Windows to find the disk.
Did that too, I went right back to TestDisk and what I saw was the exact same thing as before, that's why I think TestDisk never actually wrote anything to my disk.
muffinman
#6 Post by muffinman »
Fiona wrote:If a partition appears as RAW indicates, either a faulty boot sector or a damaged file system.
Hi Fiona,
Here's the current partition structure under the Quick analyse screen,
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63
>* HPFS - NTFS 0 32 33 243201 45 44 3907024896 [Store]
Here's the log file, after a deep analysis;
Sun Apr 14 11:15:50 2013
TestDisk 6.14-WIP, Data Recovery Utility, April 2013
Compilation date: 2013-04-11T19:48:47
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=250059350016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500106788864
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=500105217024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202241024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=250056705024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=519241728
filewin32_getfilesize(\\.\J:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\J:) SetFilePointer err Incorrect function.
Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARS-00MVWB0, S/N:2020202057202d444d575a413141363232323139, FW:51.0AB51
Disk /dev/sdb - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - WDC WD2500JS-40MVB1, S/N:2020202057202d444d574e413159373236303139, FW:10.02E01
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AAKS-00TMA0, S/N:2020202057202d444d5750413157313433313034, FW:12.01C01
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000333AS, S/N:2020202020202020202020205435304551353239, FW:SD15
Disk /dev/sde - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AAKX-001CA0, S/N:2020202057202d444d5759413055333430353838, FW:15.01H15
Drive H: - 519 MB / 495 MiB - CHS 123 64 32, sector size=2048 - PIONEER DVD-RW DVR-216, FW:1.04
Disk /dev/sda - 2000 GB / 1863 GiB - WDC WD20EARS-00MVWB0
Analyse Disk /dev/sda - 2000 GB / 1863 GiB - CHS 243201 255 63
NTFS at 0/32/33
1 * HPFS - NTFS 0 32 33 243201 45 44 3907024896 [Store]
NTFS at 0/32/33
filesystem size 3907024896
mftmirr_lcn 2
file_pread(4,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(4,1,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(4,8,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(4,8,buffer,3907029376(243201/84/20)) lseek err Invalid argument
file_pread(4,8,buffer,3907029504(243201/86/22)) lseek err Invalid argument
file_pread(4,8,buffer,3907029632(243201/88/24)) lseek err Invalid argument
file_pread(4,8,buffer,3907029760(243201/90/26)) lseek err Invalid argument
file_pread(4,8,buffer,3907029888(243201/92/28)) lseek err Invalid argument
file_pread(4,8,buffer,3907030016(243201/94/30)) lseek err Invalid argument
file_pread(4,8,buffer,3907030144(243201/96/32)) lseek err Invalid argument
file_pread(4,8,buffer,3907030272(243201/98/34)) lseek err Invalid argument
file_pread(4,8,buffer,3907030400(243201/100/36)) lseek err Invalid argument
file_pread(4,8,buffer,3907030528(243201/102/38)) lseek err Invalid argument
file_pread(4,8,buffer,3907030656(243201/104/40)) lseek err Invalid argument
file_pread(4,8,buffer,3907030784(243201/106/42)) lseek err Invalid argument
file_pread(4,8,buffer,3907030912(243201/108/44)) lseek err Invalid argument
file_pread(4,7,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(4,8,buffer,3907031048(243201/110/54)) lseek err Invalid argument
file_pread(4,3,buffer,3907031056(243201/110/62)) lseek err Invalid argument
file_pread(4,3,buffer,3907031103(243201/111/46)) lseek err Invalid argument
file_pread(4,8,buffer,3907031119(243201/111/62)) lseek err Invalid argument
file_pread(4,11,buffer,3907031166(243201/112/46)) lseek err Invalid argument
file_pread(4,2,buffer,3907033088(243201/143/15)) lseek err Invalid argument
NTFS at 0/32/33
mftmirr_lcn 2
file_pread(4,16,buffer,984883326(61306/38/43)) ReadFile Data error (cyclic redundancy check).
file_pread(4,16,buffer,1877338112(116858/227/42)) ReadFile Data error (cyclic redundancy check).
file_pread(4,1,buffer,1877338112(116858/227/42)) ReadFile Data error (cyclic redundancy check).
file_pread(4,1,buffer,1877338111(116858/227/41)) ReadFile Data error (cyclic redundancy check).
file_pread(4,15,buffer,1877338113(116858/227/43)) ReadFile Data error (cyclic redundancy check).
file_pread(4,16,buffer,1877338175(116858/228/42)) ReadFile Data error (cyclic redundancy check).
file_pread(4,16,buffer,1877338191(116858/228/58)) ReadFile Data error (cyclic redundancy check).
file_pread(4,1,buffer,1877338191(116858/228/58)) ReadFile Data error (cyclic redundancy check).
BAD_RS LBA=2487853387 485930
FAT12 154861 181 20 320756 17 63 2665092887
This partition ends after the disk limits. (start=2487853387, size=2665092887, end=857978977, disk end=3907029168)
NTFS at 243201/45/44
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
file_pread(4,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
The harddisk (2000 GB / 1863 GiB) seems too small! (< 2638 GB / 2457 GiB)
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 11-Apr-2013 03:11 .
5 dr-xr-xr-x 0 0 0 11-Apr-2013 03:11 ..
35 dr-xr-xr-x 0 0 0 18-Feb-2012 10:40 $RECYCLE.BIN
3114 -r--r--r-- 0 0 370845362 26-Jun-2010 14:30 Deceived Cinematic Trailer.avi
13653 dr-xr-xr-x 0 0 0 26-May-2012 17:43 Downloads
3080 -r--r--r-- 0 0 384624737 11-Aug-2012 13:49 Lily Dance.MOV
42 dr-xr-xr-x 0 0 0 7-Apr-2013 15:15 Moviez
3425 dr-xr-xr-x 0 0 0 31-Jan-2011 22:31 msdownld.tmp
3346 dr-xr-xr-x 0 0 0 11-Sep-2011 15:51 Norton Backups
3426 dr-xr-xr-x 0 0 0 1-Feb-2011 07:25 Pictures
3188 -r--r--r-- 0 0 4714890240 16-Mar-2011 21:51 Sodexo Email backup.pst
3328 -r--r--r-- 0 0 4776600576 14-Mar-2011 20:02 Sodexo Emails.pst
13077 dr-xr-xr-x 0 0 0 7-Mar-2012 22:06 The Book Wakeboard Instructional Series
3112 -r--r--r-- 0 0 214665010 26-Jun-2010 12:39 The Force Unleashed 2 Trailer.avi
3113 -r--r--r-- 0 0 269118871 26-Jun-2010 12:40 The Old Republic - Hope.wmv
13858 dr-xr-xr-x 0 0 0 29-Jun-2012 07:29 The Pink Panther Cartoons
2956 dr-xr-xr-x 0 0 0 10-Apr-2013 02:30 Trailers
3347 dr-xr-xr-x 0 0 0 11-Sep-2011 15:51 VProRecovery
3115 -r--r--r-- 0 0 3319478272 8-Mar-2011 09:58 Windows_7_Professional_with_Service_Pack_1_64_bit_English_X17-24281.IMG
13500 dr-xr-xr-x 0 0 0 16-Sep-2012 15:29 Word
12701 dr-xr-xr-x 0 0 0 14-May-2011 17:53 Omi's Kitchen 1 2011-05-14 - 2011-05-14
15078 -r--r--r-- 0 0 6822254592 17-Jan-2013 09:23 SW_DVD9_NTRL_Win_Small_Bus_Svr_Std_2011_64Bit_English_FPP_VL_X16-93854.ISO
3393 dr-xr-xr-x 0 0 0 23-Dec-2010 21:48 System Volume Information
I hope this helps?
muffinman
#7 Post by muffinman »
Anyone please?
