I can't get disktest to show me my old partition name, i can however see the files in media recovery software.
I am confident that disktest will be successful if I can get some help with punching the right settings.
My LIFE is on my raid, and the directory structure and file names are super important.
There are 8 WD Caviar Black drives in the HW raid5 tower connected via dual SAS to an Areca card.
So far the only thing I have done is reformatted the drive with a new name.
This is my system profiler info:
SCSI Logical Unit @ 0:
Capacity: 7 TB (6,999,999,512,576 bytes)
SCSI Logical Unit Number: 0
Manufacturer: MAXX
Model: MAXX1221-VOL#00
Revision: R001
Removable Media: Yes
Detachable Drive: No
BSD Name: disk6
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Not Supported
I won't be able to sleep, or live until I get this back the way it was.
Why doesn't the Undo button in disk utility do anything anyway. It's inevitable for mess ups.
