Recovering Data / Disk using TestDisk
TomT
NAS Drive failed - help please
#1 Post by TomT »
My NAS Drive stopped working today.
Its a Western Digital my world book, white light 1TB single disk.
I've taken the disk out of the bay and connected it using a SATA to USB cable.
I've run test disk and its returned this :
Running Test Disk
Shows this for the drive:
Analyse cylinder 402/121600: 00%
MS Data 64320 3984063 3919744
Linux Raid 64320 3984191 3919872 [md0]
Linux Swap 3984192 4497967 513776
Linux Raid 3984192 4498111 513920 [md1]
MS Data 4498176 6473983 1975808
Linux Raid 4498176 6474111 1975936 [md3]
Linux Raid 6474176 1953524869 1947050694 [MyBookWorld:2]
Now I've now idea what to do..
Help Please :-)
Thanks
TomT
#2 Post by TomT »
Hi
Yesterday my Western Digital My World Book White Light NAS Drive stopped working.
This has a single 1TB Disk.
At first I started getting the following error:
Volume Status - Volume 'DataVolume' doesn't exist
Then the NAS refused to boot.
So I've removed the disk from the NAS and connected it to my Ubuntu laptop using a SATA to USB Cable.
Running test disk returns this :
Code:
Sat Apr 20 08:40:11 2013
TestDisk 6.11, Data Recovery Utility, April 2009
OS: Linux, kernel 3.0.0-21-generic (#35-Ubuntu SMP Fri May 25 17:58:20 UTC 2012)
Compiler: GCC 4.5 - Oct 17 2010 20:12:36
ext2fs lib: 1.41.14, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: size       312581808 sectors
/dev/sda: user_max   312581808 sectors
/dev/sda: native_max 312581808 sectors
/dev/sda: dco        312581808 sectors
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ATA ST9160310AS
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 EARS-00MVWB0
Disk /dev/sdb - 1000 GB / 931 GiB - WDC WD10 EARS-00MVWB0
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953525167 (expected 1953525167)
hdr_lba_start=34
hdr_lba_end=1953525134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34     262177     262144 [Microsoft reserved partition]
No FAT, NTFS, EXT2, JFS, Reiser, cramfs or XFS marker
recover_EXT2: s_block_group_nr=0/14, s_mnt_count=100/33, s_blocks_per_group=32768, s_inodes_per_group=16352
recover_EXT2: s_blocks_count 489968
recover_EXT2: part_size 3919744
     EXT3 Sparse superblock, 2006 MB / 1913 MiB
Raid magic value at 247/254/8
Raid apparent size: 3919744 sectors
Raid chunk size: 0 bytes
md0 md 0.90.0 Raid 1: devices 0(8,1)*
     md 0.90.0 Raid 1: devices 0(8,1)*, 2006 MB / 1914 MiB
     SWAP2 version 1, 263 MB / 250 MiB
Raid magic value at 279/251/37
Raid apparent size: 513792 sectors
md1 md 0.90.0 Raid 1: devices 0(8,2)*
     md 0.90.0 Raid 1: devices 0(8,2)*, 263 MB / 250 MiB
recover_EXT2: s_block_group_nr=0/7, s_mnt_count=82/23, s_blocks_per_group=32768, s_inodes_per_group=7728
recover_EXT2: s_blocks_count 246976
recover_EXT2: part_size 1975808
     EXT3 Large file Sparse superblock, 1011 MB / 964 MiB
Raid magic value at 402/251/42
Raid apparent size: 1975808 sectors
md3 md 0.90.0 Raid 1: devices 0(8,3)*
     md 0.90.0 Raid 1: devices 0(8,3)*, 1011 MB / 964 MiB
Raid magic value at 402/254/45
Raid apparent size: 3733254810 sectors
MyBookWorld:2 md 1.x Raid 1 - Array Slot : 0 (0)
     md 1.x Raid 1 - Array Slot : 0 (0), 996 GB / 928 GiB
   P Linux Raid               6474176 1953524869 1947050694 [MyBookWorld:2]
When I run testdisk the results table shows all the entries with a D in front of them, apart from the last one which has a P
Could someone please advise what this means and more importantly if my data is recoverable and how ??
Many Thanks
TomT
Re: Recovering Data / Disk using TestDisk
#3 Post by TomT »
Hi
Anyone any ideas how to proceed ?
I've left it doing a deep scan all day, As yet it's still going but should be finishing in the next hour.
Once it has.... I've no idea what to do.
All I want to do is make it so the disk is visible to Linux or Windows, so I can copy my data off..
Please help :(
TomT
#4 Post by TomT »
We'll it's just finished..
and this is the result :
The harddisk (1000 GB / 931 GiB) seems too small! (< 1965 GB / 1830 GiB)
     MS Data                 67319776 2014370271 1947050496
     XFS 6.2+ - bitmap version, 996 GB / 928 GiB
     MS Data                128165104 2075215599 1947050496
     Mac HFS                128167720 2074956007 1946788288
     HFSX, 996 GB / 928 GiB
     Mac HFS                128190436 2074978723 1946788288
This goes on for thousands of lines........
Any help will be very gratefully appreciated :)
TomT
#5 Post by TomT »
Couple some one please help with this..
I really need to get access to my data..
