Recover Raid 1 only recover 1 partition.
I had a iomega 2GB 2x1GB external hard drive enclosure. It was configured for raid 1 with switches on the box. One drive died and the data became unavailable on the remaining drive. I have used testdisk to recover some of the data. There use to be two data partitions but I can find only one. I used testdisk to write something to the drive, I may have made a mistake doing this. I did a deep scan to try and find the other partition but got a error about a FAT12 partion being too small. I am attaching a log file with the file name removed. Is there a way I can try to find the other partition?
Re: Recover Raid 1 only recover 1 partition.
Mon Apr 22 05:20:09 2013
TestDisk 6.14-WIP, Data Recovery Utility, April 2013
OS: Windows XP SP3
Compilation date: 2013-04-22T08:36:13
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=32017047552
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=32017047552
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=32004532224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000395698176
Disk /dev/sda - 32 GB / 29 GiB - CHS 3892 255 63, sector size=512 - Corsair CSSD-V32GB2, S/N:3131313135363532303030303031303231313433, FW:2.2
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000528AS, FW:CC44
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WD Ext HDD 1021, FW:2002
Disk /dev/sdb - 1000 GB / 931 GiB - ST31000528AS
check_part_i386 1 type 42: no test
1 P W2K Dynamic/SFS 0 1 1 121594 254 63 1953423612
Backup partition structure
partition_save
BAD_RS LBA=4057832021 4294967295
file_pread(5,3,buffer,4057832021(252588/92/6)) lseek err Invalid argument
file_pread(5,1,buffer,4057832021(252588/92/6)) lseek err Invalid argument
FAT12 252588 92 6 430474 128 32 2857740885
This partition ends after the disk limits. (start=4057832021, size=2857740885, end=2620605609, disk end=1953525168)
file_pread(5,15,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(5,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(5,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(5,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 3540 GB / 3297 GiB)
interface_load
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63 Mon Apr 22 05:21:24 2013
interface_load
interface_load
interface_load
Change partition type:
1 P HPFS - NTFS 0 1 1 121594 254 63 1953423612
Not an exFAT boot sector.
New options :
Dump : No
Align partition: Yes
Expert mode : No
New options :
Dump : No
Expert mode : No
ntfs_boot_sector
filesystem size 1 1
sectors_per_cluster 0 0
mft_lcn 0 0
mftmirr_lcn 0 0
clusters_per_mft_record 0 0
clusters_per_index_record 0 0
Status: Bad
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
mft at 6291456, seq=1, main=0 res=1
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 63999999
New / Current boot sector
filesystem size 1953423612 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 63999999 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
mft_lcn 786432 0
5 dr-xr-xr-x 0 0 0 29-Mar-2013 01:26 .
5 dr-xr-xr-x 0 0 0 29-Mar-2013 01:26 ..
78400 dr-xr-xr-x 0 0 0 2-Apr-2013 12:00 System Volume Information
mft_lcn 786432 0
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
Search mft stopped: 786432/1953423612
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
New options :
Dump : No
Expert mode : No
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
mft_lcn 786432 0
mft_lcn 786432 0
Write new boot!
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
Sectors are identical.
Failed to open inode: Input/output error.
repair_MFT
NTFS at 0/1/1
ntfs_readdir failed for cluster 5
NTFS listing using MFT:
ntfs_dir: ntfs_inode_open failed
ntfs_boot_sector
1 P HPFS - NTFS 0 1 1 121594 254 63 1953423612 [ExternalRaid]
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
repair_MFT
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
partition_save
NTFS at 0/1/1
* HPFS - NTFS 0 1 1 121594 254 63 1953423612 [ExternalRaid]
interface_load
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63 Mon Apr 22 22:20:40 2013
dir_partition inode=5
Invalid partition structure.
NTFS at 0/1/1
1 * HPFS - NTFS 0 1 1 121594 254 63 1953423612 [ExternalRaid]
NTFS at 0/1/1
NTFS at 121594/254/63
NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
dir_partition inode=78400
Directory /System Volume Information
78400 dr-xr-xr-x 0 0 0 2-Apr-2013 12:00 .
dir_partition inode=80173
Directory /Restore
80173 dr-xr-xr-x 0 0 0 19-Nov-2012 14:05 .
Directory /Restore
dir_partition inode=27
Directory /Restore/Backups
27 dr-xr-xr-x 0 0 0 10-Jul-2012 07:36 .
80173 dr-xr-xr-x 0 0 0 19-Nov-2012 14:05 ..
dir_partition inode=28
Directory /Restore/Backups/G
dir_partition inode=29
Directory /Restore/Backups/O
dir_partition inode=141237
Directory /Restore/L
dir_partition inode=294694
294694 dr-xr-xr-x 0 0 0 19-Nov-2012 10:49 .
141237 dr-xr-xr-x 0 0 0 19-Nov-2012 10:49 ..
Directory /Restore
dir_partition inode=80302
Directory /f423fea879808aa4ec3d030f56
Directory /Restore
No partition 121595 0 1 121600 254 63 96390
HPFS - NTFS 121595 0 1 121600 254 63 96390
2 * HPFS - NTFS 121595 0 1 121600 254 63 96390
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
repair_MFT
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
New options :
Dump : No
Expert mode : No
partition_save
NTFS at 0/1/1
P HPFS - NTFS 121595 0 1 121600 254 63 96390
2 P HPFS - NTFS 121595 0 1 121600 254 63 96390
OS: Windows XP SP3
partition_save
interface_load
interface_load
interface_load
interface_load
New options :
Dump : No
Expert mode : No
New options :
Dump : No
Expert mode : No
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
mft_lcn 786432 0
mft_lcn 786432 0
mft_lcn 786432 0
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
New options :
Dump : No
Expert mode : No
ntfs_boot_sector
filesystem size 1 1
mft_lcn 0 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
mft_lcn 786432 0
mft_lcn 786432 0
Write new boot!
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
repair_MFT
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
repair_MFT
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
partition_save
NTFS at 0/1/1
interface_load
NTFS at 0/1/1
NTFS at 0/1/1
Directory /Restore
Directory /Restore
Directory /Restore
Directory /Restore
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
repair_MFT
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
Status: OK
Status: OK
New options :
Dump : No
Expert mode : No
partition_save
NTFS at 0/1/1
I already used testdisk to write the partition table, is there still a way to recover my missing partitions?
