EML file type?
MSSMallBiz
EML file type?
Any chance of getting the Windows Live Mail and other email clients EML format included? I see you have one for Mac, I assume the structure is different enough it wouldn't find Live Mail files?
Re: EML file type?
Or .rdl (Report description files). Of course, these are xml files but without the xml suffix. Perhaps what is needed it to have an option to add new file types. Another probably easy feature would be to be able to select file types from the list and have the option to filter by what's in the file list OR filter to NOT include depending on the list.
At any rate, does not selecting from the file type selection list default to 'all'?
