Need help recovery 3Tb NTFS partition
Ultreme
#1 Post by Ultreme »
I have formatted my external drive by error. It's a WD My Book 3Tb and had previously only one NTFS partition of 2.7Tb. It is now formatted with FAT32.
I have run Testdisk Analyse, quick search and deep search but cannot find my files.
What can i do ?
Thanks for your help.
Here's below the logfile of Testdisk :
Tue May 14 22:14:38 2013
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=3000558944256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=3000558944256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=159671910400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000557895680
filewin32_getfilesize(\\.\F:) GetFileSize err Fonction incorrecte.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Fonction incorrecte.
file_pread(4,1,buffer,312592769(19457/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,732563999(45599/254/63)) lseek err Invalid argument
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - INTEL SSDSA2CW160G3, S/N:CVPR14510A7J160DGN, FW:4PC10362
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 45599 255 63, sector size=4096 - WD My Book 1140, S/N:WMC1T1372329, FW:1019
Disk \\.\PhysicalDrive1 - 3000 GB / 2794 GiB - CHS 45599 255 63, sector size=4096 - WD My Book 1140, S/N:WMC1T1372329, FW:1019
Drive E: - 3000 GB / 2794 GiB - CHS 45599 255 63, sector size=4096 - WD My Book 1140, S/N:WMC1T1372329, FW:1019
Disk /dev/sdb - 3000 GB / 2794 GiB - WD My Book 1140
Analyse Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 45599 255 63
Invalid NTFS or EXFAT boot
1 P HPFS - NTFS 0 4 5 45599 165 6 732558080
Computes LBA from CHS for Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 45600 255 63
search_vista_part: 1
FAT32 at 0/4/5
FAT1 : 32-22399
FAT2 : 22400-44767
start_rootdir : 44768 root cluster : 2
Data : 44768-732558079
sectors : 732558080
cluster_size : 32
no_of_cluster : 22891041 (2 - 22891042)
fat_length 22368 calculated 22355
FAT32 at 0/4/5
FAT32 LBA 0 4 5 45599 165 6 732558080 [New Volume]
FAT32, 3000 GB / 2794 GiB
file_pread(5,1,buffer,732558337(45599/165/8)) lseek err Invalid argument
file_pread(5,1,buffer,732558338(45599/165/9)) lseek err Invalid argument
file_pread(5,2,buffer,732558343(45599/165/14)) lseek err Invalid argument
file_pread(5,2,buffer,732558345(45599/165/16)) lseek err Invalid argument
file_pread(5,3,buffer,732558351(45599/165/22)) lseek err Invalid argument
file_pread(5,1,buffer,732558592(45599/169/11)) lseek err Invalid argument
* FAT32 LBA 0 4 5 45599 165 6 732558080 [New Volume]
1 * FAT32 LBA 0 4 5 45599 165 6 732558080 [New Volume]
FAT32 at 0/4/5
FAT1 : 32-22399
FAT2 : 22400-44767
sectors : 732558080
cluster_size : 32
FAT32 at 0/4/5
dir_partition inode=0
FAT: cluster=2(0x2), pos=45024
3 drwxr-xr-x 0 0 0 14-May-2013 22:06 $RECYCLE.BIN
X 5 drwxr-xr-x 0 0 131072 15-May-2013 05:26 _325270_
X 5 drwxr-xr-x 0 0 131072 15-May-2013 05:26 636f3d04e33f6261e123574a
X 5 drwxr-xr-x 0 0 131072 15-May-2013 05:30 MSI2d9a7.tmp
X 5 drwxr-xr-x 0 0 131072 15-May-2013 05:30 _562641_
X 5 drwxr-xr-x 0 0 131072 15-May-2013 05:30 2c058c3f830d37e51498f6cb8d
X 162 drwxr-xr-x 0 0 131072 15-May-2013 05:30 MSI2d9bf.tmp
X 162 drwxr-xr-x 0 0 131072 15-May-2013 05:30 MSI2d9d6.tmp
X 5 drwxr-xr-x 0 0 131072 15-May-2013 05:30 MSI33fc9.tmp
Re: Need help recovery 3Tb NTFS partition
There is still an NTFS-partition using your whole space in your partition table available.
Would it be possible to make a boot sector diagnose?
I'd like to see, will your data be listed or not?
But don't use write in TestDisk and don't change anything else to your disk.
Reason is, your disk should be a GPT disk to support partitions larger than 2.2 TB?
Confirm at Boot.
Info will follow.
Ultreme
#3 Post by Ultreme »
Thanks for your help. I remember when I got the drive, Windows properties was reporting the drive as MBR. It seems that Western Digital use some kind of trick to make drive larger than 2.2Tb in MBR.
I did what you ask, but the List command did nothing. It was like I didn't execute it.
Here's the logfile :
Wed May 15 09:41:50 2013
Not an exFAT boot sector.
ntfs_boot_sector
filesystem size 8589934593 1
sectors_per_cluster 32 0
mft_lcn 393217 0
mftmirr_lcn 0 0
clusters_per_mft_record 0 0
clusters_per_index_record -66 0
Status: Bad
Status: Bad
Sectors are not identical.
$MFTMirr location mismatch or first 4 records are fragmented. Run chkdsk.
Failed to load $MFTMirr: Input/Output error.
rebuild_NTFS_BS
mft at 366279039, seq=1, main=0 res=1
read_mft_info failed
ntfs_find_mft: sectors_per_cluster invalid
ntfs_find_mft: mft_lcn 786432
ntfs_find_mft: mftmirr_lcn 2
ntfs_find_mft: mft_record_size 4096
mft at 786432, seq=1, main=0 res=1
ntfs_find_mft: sectors_per_cluster 1
New / Current boot sector
filesystem size 732558080 8589934593
sectors_per_cluster 1 32
mft_lcn 786432 393217
mftmirr_lcn 2 0
clusters_per_mft_record 1 0
clusters_per_index_record 1 -66
mftmirr_lcn 2 0
mftmirr_lcn 2 0
mftmirr_lcn 2 0
ntfs_boot_sector
mft_lcn 393217 0
mftmirr_lcn 0 0
Status: Bad
Status: Bad
#4 Post by Fiona »
TestDisk didn't find any boot sector during searching for a file system and files.
Might be possible that your partition in your partition table doesn't match.
Chkdsk is a utility to have a try to repair a file system but it's not intended to recover data.
It can increase damage, that's why it's on your own risk.
To have a try to find a partition containing your data, you should run Deeper Search.
If more partitions are found, please mark them and press p to have a try to list your files!
Please upload a log again!
A tip is, if testdisk finds any partition with your label, you can press F (upper case) to jump to the end to the partition.
It can save time, scanning a large disk.
Ultreme
#5 Post by Ultreme »
Hi, thanks again.
I've already did the deap search. It's in the first log I've post. It only find the new FAT32 partition.
Maybe I don't understand well what you want me to do.
#6 Post by Fiona »
Sry for my bad explanation.
Your try to diagnose your boot sector, testdisk reported that the file system is damaged.
Info:
Your're right, I checked your log in your first post and you were already running Deeper Search.
Normally a disk larger than 2.2 TB should be a GPT-disk.
In your diagnose, you used intel partition table.
Do you have any idea, how your disk was previously partitioned?
Has it been a GPT disk or an Intel MBR disk?
Using disks larger than 2.2 TB as an Intel- MBR disk is not supported and can cause loss of data.
If you make a diagnose using Intel MBR and your disk is a GPT-disk, it might be possible that testdisk doesn't find your partition because Intel MBR searches partition in Cylinders and not sectors.
Please let me know, did you have previously an Intel-MBR or a GPT-disk.
Ultreme
#7 Post by Ultreme »
I'm pretty confident it was an Intel MBR disk. It seems Western Digital uses 4K LBA instead of 512bytes to be able to have 2.7tb MBR disk.
I have never reformated the drive since I bought it. I remember that Windows 7 x64 reported it as an MBR drive but the disk management utility had trouble showing the 2.7tb partition. I think it was reported as a 746Gb partition in that utility while Windows Explorer reported the 2.7Gb drive without problem.
thanks again.
Ultreme
#8 Post by Ultreme »
I saw an older thread where the partition seems to have been rebuilt manually. Is this something I could do ?
http://forum.cgsecurity.org/phpBB3/reco ... d-t15.html
dwardlaw
#9 Post by dwardlaw »
I have exactly the same problem with a 3TB Western Digital drive. I am getting a "Partition sector doesn't have the endmark 0xAA55". When analysing I get invalid FAT boot sector. I too am unsure on how to proceed.
