I have a gopro hero HD that I took various videos and stills on, when the card went bad.
Using the GoPro as a mass storage device, I get the disk to come up in windows 7 64bit, but it says it needs formatted. When I load Photorec or testdisk the disk is not listed.
When I load it in to a card reader, I get nothing at all. I get the beep of a usb device but then nothing else. It doesn't show up in windows or the recovery software.
I have checked the card reader and go pro with a good card, both work perfectly.
Any ideas? What am I missing?
Thanks for all the help!
Can't find disk
Re: Can't find disk
You could try PC Inspector File Recovery by Convar. It has a "Find lost drives" function that might be able to see your card.
