I am mounting a TrueCrypt partition ok as F: but when i try to access it, system tells me it is unreadable.
This happened while i was at the computer. F: was doing ok and all of the sudden windows tells me cannot use F anymore. If i mount the partition with the wrong password, it tells me so.
I dismounted, mounted the partition, same result. Restarted the computer, mounted, same result.
After reading the forums, i tried recovering it with TestDisk
http://pastebin.com/5nNTg3Y1
and looked over more instructions on
http://www.cgsecurity.org/wiki/Recover_ ... ypt_Volume
I followed the exact steps from http://pastebin.com/5nNTg3Y1
but at step 8 when i choose "Rebuild BS", TestDisk starts doing it but it hangs everytime at:
"Search mft  458752 / 307199521"
Waited more than 30 minutes, testdisk didnt change.
Trying the option "Stop" does do anything. Again, pressed ENTER and waited ~30 minutes, nothing stopped..
The only way to "stop" it is to manually close the app..
Trying Repair MFT fails saying the Cant'read NTFS MFT.
Anyone has any ideas about what i could try to get my files back ?
This is what is being listed after i choose Boot in TestDisk:
Warning: number of heads/cylinder mismatches 16 (NTFS) != 1 (HD)
Warning: number of sectors per track mismatches 63 (NTFS) != 1 (HD)
Status: OK
Status: OK
Sectors are identical.
My system is Windows 7 64bit
using TrueCrypt 7.1 and TestDisk 6.14
Hardrives are SATA.
I just left the computer running overnight with the rebuild bs option.
When i got up this is what the log showed :
rebuild_NTFS_BS
file_win32_pread(304,16,buffer,492032(492032/0/1)) read err: read after end of file
file_win32_pread(304,16,buffer,492225(492225/0/1)) read err: read after end of file
file_win32_pread(304,16,buffer,492226(492226/0/1)) read err: read after end of file
(... many lines like above )
						Problems recovering of a truecrypt partion
