This is a long story because I have no idea what is relevant & what is not.
I have an old AMD system with two hard disks:
ST380011A 80G IDE
ST3160827AS 160G SATA
Originally I ran WinXP which booted off ST380011A. I wanted to install Win7 but, as there was no way to automatically migrate apps from WinXP to Win7, I discovered a way to run the both OSes by changing a configuration item in the BIOS. If I switched on RAID in the BIOS it changed the boot order of the hard disks from IDE to SATA. So I installed Windows 7 successfully onto the SATA drive. If I wish to run XP I just switch off RAID in the BIOS & it boots XP off the IDE drive. This has worked well for a long time but a week ago I got the following error when turning on my PC:
Windows Boot Manager
Status: 0x000000e
The boot selection failed because because a required device is inaccessible
I searched web for fix but nothing worked.
If I boot into XP on IDE drive I appear to be able to access all my data on the SATA drive. I just can't boot from it.
By chance I tried the AVG rescue CD which had a copy of TestDisk on it when I ran it, TeskDisk found Incorrect number of heads/cylinder 16 (NTFS) !=255 (HD). This meant nothing to me other than there appeared to something wrong with hard disk. Anyway I couldn't find log file (because I was booting off CD?). So I ran TestDisk after booting PC in WinXP and got the following from the log file:
Analyse Disk /dev/sdb - 160 GB / 149 GiB - CHS 19457 255 63
Geometry from i386 MBR: head=16 sector=63
BAD_RS LBA=2048 32162
NTFS at 0/32/33
BAD_RS LBA=206848 3293533
NTFS at 12/223/20
Warning: number of heads/cylinder mismatches 16 (NTFS) != 255 (HD)
 1 * HPFS - NTFS              0  32 33    12 223 19     204800 [System Reserved]
Bad relative sector.
 2 P HPFS - NTFS             12 223 20 19457  21 20  312371200
I also got the following when doing a partition search:
NTFS at 0/1/1
filesystem size           312576641
sectors_per_cluster       32
mft_lcn                   153170
mftmirr_lcn               154634
clusters_per_mft_record   -10
clusters_per_index_record -12
     HPFS - NTFS              0   1  1 19456 254 62  312576641
     NTFS, blocksize=16384, 160 GB / 149 GiB
file_pread(5,2,buffer,312582144(19457/86/22)) lseek err Invalid argument
file_pread(5,1,buffer,312582144(19457/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,312581823(19457/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,312581823(19457/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,312581951(19457/83/18)) lseek err Invalid argument
file_pread(5,8,buffer,312582079(19457/85/20)) lseek err Invalid argument
file_pread(5,1,buffer,312582143(19457/86/21)) lseek err Invalid argument
file_pread(5,14,buffer,312582145(19457/86/23)) lseek err Invalid argument
file_pread(5,3,buffer,312582159(19457/86/37)) lseek err Invalid argument
file_pread(5,3,buffer,312582206(19457/87/21)) lseek err Invalid argument
file_pread(5,8,buffer,312582222(19457/87/37)) lseek err Invalid argument
file_pread(5,11,buffer,312582269(19457/88/21)) lseek err Invalid argument
file_pread(5,2,buffer,312584191(19457/118/53)) lseek err Invalid argument
   * HPFS - NTFS              0   1  1 19456 254 63  312576642
Is there anything I can do fix the SATA drive with TestDisk? My main concern is ensuring that whatever I do does not cause me to lose all the data which still exists on the drive.
Any help would be greatly appreciated.
						Can't boot from drive
