please I need help recovering my files on my 2TB HDD. I've tried to recover files from
my friend's external 500GB HDD which was not mounting in windows, by kroll ontrack easyrecovery software - choosing Copy Disk and copying external HDD to my computer was very bad idea. Now even my HDD is in RAW and not accessible.
This is my log from Testdisk:
Quick search only found some weird FAT16 unrecoverable partition. This partition ends after the disk limits. (start=4100259221, size=1081306929, end=886598853, disk end=3907029168).
After deep search it found my NTFS partition, with these parameters:
0 32 33 243201 45 44 3907024896
Shouldn't it be 0 1 1 something?
There is also warning> The harddisk (2000 GB / 1863 GiB) seems too small! (< 2652 GB / 2470 GiB).
It seems like there has been added those 500Gb to my 2TB disk?
When I try to list the files, it says the file system is corrupted
TestDisk 6.14-WIP, Data Recovery Utility, May 2013
Compilation date: 2013-05-25T13:15:04
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=128035676160
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63 (RO), sector size=512 - M4-CT128M4SSD1, S/N:3030303030303030323137313930383039433842, FW:000F
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63 (RO), sector size=512 - ST2000DM001-9YN164, S/N:202020202020202020202020325a3046394e374a, FW:CC4B
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63 (RO), sector size=512 - WDC WD10EARS-003BB1, S/N:2020202057202d44435756414d35383337303534, FW:80.00A80
Media is opened in read-only.
Disk /dev/sdb - 2000 GB / 1863 GiB (RO) - ST2000DM001-9YN164
 1 * HPFS - NTFS              0  32 33 243201  45 44 3907024896
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
Analyse Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63 (RO)
Invalid NTFS or EXFAT boot
BAD_RS LBA=4100259221 6081
file_pread(5,3,buffer,4100259221(255229/84/45)) lseek err Invalid argument
file_pread(5,1,buffer,4100259221(255229/84/45)) lseek err Invalid argument
     FAT16 <32M           255229  84 45 322537 146 47 1081306929
file_pread(5,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(5,14,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(5,3,buffer,3907031055(243201/110/61)) lseek err Invalid argument
file_pread(5,3,buffer,3907031102(243201/111/45)) lseek err Invalid argument
file_pread(5,8,buffer,3907031118(243201/111/61)) lseek err Invalid argument
file_pread(5,11,buffer,3907031165(243201/112/45)) lseek err Invalid argument
file_pread(5,2,buffer,3907033087(243201/143/14)) lseek err Invalid argument
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 243201/45/44
filesystem size           3907024896
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     NTFS found using backup sector, blocksize=4096, 2000 GB / 1863 GiB
file_pread(5,8,buffer,3907029248(243201/82/18)) lseek err Invalid argument
file_pread(5,8,buffer,3907029376(243201/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,3907029504(243201/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,3907029632(243201/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,3907029760(243201/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,3907029888(243201/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,3907030016(243201/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,3907030144(243201/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,3907030272(243201/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,3907030400(243201/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,3907030528(243201/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,3907030656(243201/104/40)) lseek err Invalid argument
file_pread(5,8,buffer,3907030784(243201/106/42)) lseek err Invalid argument
file_pread(5,8,buffer,3907030912(243201/108/44)) lseek err Invalid argument
Not an exFAT boot sector.
Change partition type:
write!
file_nopwrite(5,1,buffer,0(0/0/1)) write refused
Partition: Write error
ntfs_boot_sector
NTFS at 0/32/33
filesystem size           1 3907024896
sectors_per_cluster       0 8
mft_lcn                   0 786432
mftmirr_lcn               0 2
clusters_per_mft_record   0 -10
clusters_per_index_record 0 1
Status: Bad
Status: OK
Sectors are not identical.
rebuild_NTFS_BS
Search mft stopped:   49152000/3907024896
