MFT / bad sectors problem - solutions good? log file attachd
Deleted User 1406
#1 Post by Deleted User 1406 »
Background: Did perhaps Windows update... but definitely did an AVG update which required reboot. It wouldn't reboot... hdd had a clicking noise.
Things tried:
technician tried to give more power to get hdd spinning.
I tried freezing hdd. Worked; was able to copy only one file.
created a test disk clone of data partition; it does not seem to mount/be accessible (because mft is bad??)
On seeing bad ntfs boot sector ; tried to rebuild boot sector / repair mft... stopped at where the prompt asks for sectors per cluster (wrong entry disasterous???)
Will getdataback or ntfswalker work??? Or does it look hopeless?
Here is my log file:
Mon Jun 24 13:30:58 2013
TestDisk 6.14-WIP, Data Recovery Utility, May 2013
OS: Linux, kernel 3.8.0-19-generic (#29-Ubuntu SMP Wed Apr 17 18:16:28 UTC 2013) x86_64
Compiler: GCC 4.4
Compilation date: 2013-05-25T13:17:44
ext2fs lib: 1.41.12, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504
/dev/sda: size 1953525168 sectors
/dev/sda: user_max 1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sda: dco 1953525168 sectors
/dev/sdb: LBA, LBA48, DCO support
/dev/sdb: size 976773168 sectors
/dev/sdb: user_max 976773168 sectors
/dev/sdb: dco 976773168 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EZEX-00RKKA0, S/N:WD-WMC1S4487860, FW:80.00A80
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AAKX-603CA0, S/N:WD-WCAYUDJ85166, FW:18.01H18
Disk /dev/sdc - 16 GB / 14 GiB - CHS 15287 64 32, sector size=512 - Kingston DataTraveler 2.0, FW:1.00
Disk /dev/sdb - 500 GB / 465 GiB - WDC WD5000AAKX-603CA0
NTFS at 0/32/33
file_pread(5,4096,buffer,6293504(391/191/57)) read err: Input/output error
file_pread(5,1,buffer,6293504(391/191/57)) read err: Input/output error
NTFS: Can't read MFT
file_pread(5,1,buffer,104859648(6527/53/55)) read err: Input/output error
NTFS at 32635/139/17
file_pread(5,4096,buffer,530581504(33027/43/41)) read err: Partial read
file_pread(5,1,buffer,530581520(33027/43/57)) read err: Input/output error
1 * HPFS - NTFS 0 32 33 6527 53 54 104857600
NTFS, blocksize=4096, 53 GB / 50 GiB
2 P HPFS - NTFS 6527 53 55 32635 139 16 419430400
3 P HPFS - NTFS 32635 139 17 60801 15 14 452478976
NTFS, blocksize=4096, 231 GB / 215 GiB
New options :
Dump : No
Align partition: Yes
Expert mode : Yes
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
file_pread(5,16,buffer,104859647(6527/53/54)) read err: Input/output error
file_pread(5,1,buffer,104859647(6527/53/54)) read err: Input/output error
filesystem size 104857600 1
sectors_per_cluster 8 0
mft_lcn 786432 0
mftmirr_lcn 2 0
clusters_per_mft_record -10 0
clusters_per_index_record 1 0
Status: OK
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
