I think I need a little help
J0ckieboy
#1 Post by J0ckieboy »
I have a external HDD that Windows wishes to format. I would rather not as it contains my backup files. Probably not unmounting the device before shutdown resulted in some corruption.
There is only one partition and with testdisk's 'deep search' I am able to see my files. Could it be that the MBR is wrong?
Here is some of the logfile (Is this enough information?):
Disk /dev/sdb - 300 GB / 279 GiB - USB-HS SAMSUNG HD300LD
Analyse Disk /dev/sdb - 300 GB / 279 GiB - CHS 36481 255 63
FAT32 at 0/1/1
check_FAT: Bad number of entries in root dir
test_FAT()
 1 P FAT32                    0   1  1   140 254 63    2265102
sector_size  512
cluster_size 1
reserved     1
fats         2
dir_entries  4096
sectors      0
media        F8
fat_length   5987
secs_track   63
heads        255
hidden       63
total_sect   2265102
Invalid FAT boot sector
Ask the user for vista mode
Computes LBA from CHS for Disk /dev/sdb - 300 GB / 279 GiB - CHS 36482 255 63
search_vista_part: 1
FAT32 at 0/1/1
file_pread(5,16,buffer,507654063(31600/1/1)) read err: Input/output error
file_pread(5,1,buffer,507654063(31600/1/1)) read err: Input/output error
file_pread(5,8,buffer,507654079(31600/1/17)) read err: Input/output error
file_pread(5,16,buffer,507654064(31600/1/2)) read err: Input/output error
file_pread(5,1,buffer,507654064(31600/1/2)) read err: Input/output error
file_pread(5,8,buffer,507654071(31600/1/9)) read err: Input/output error
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 32-71555
FAT2 : 71556-143079
start_rootdir : 143080 root cluster : 2
Data : 143080-586067175
sectors : 586067202
cluster_size : 64
no_of_cluster : 9155064 (2 - 9155065)
fat_length 71524 calculated 71524
heads/cylinder 1 (FAT) != 255 (HD)
sect/track 48519 (FAT) != 63 (HD)
FAT32 at 0/1/7
     FAT32                    0   1  1   140 238 33    2264064
     FAT found using backup sector!, 1159 MB / 1105 MiB
file_pread(5,16,buffer,507654069(31600/1/7)) read err: Input/output error
   * FAT32                    0   1  1   140 254 63    2265102
     FAT found using backup sector!, 1159 MB / 1106 MiB
dir_partition inode=0
FAT: cluster=2(0x2), pos=143143
  524465 drwxr-xr-x     0      0         0 27-Feb-2010 23:49 Books
     816 drwxr-xr-x     0      0         0 26-Feb-2006 19:38 Recycled
     817 drwxr-xr-x     0      0         0 26-Feb-2006 19:38 System Volume Information
 8571136 drwxr-xr-x     0      0         0 10-Jun-2007 22:36 TV shows
 6081908 -rwxr-xr-x     0      0     17023 23-Mar-2013 16:22 AD__0000.VCF
 2962822 drwxr-xr-x     0      0         0 31-Oct-2009 09:56 $RECYCLE.BIN
  524466 drwxr-xr-x     0      0         0 27-Feb-2010 23:50 Pictures
 1940936 drwxr-xr-x     0      0         0 28-Jan-2009 19:54 FOUND.000
 2223819 drwxr-xr-x     0      0         0 29-Aug-2013 23:08 Work
I've read several other posts and replies and I have the feeling that perhaps I should go to Advanced, select the partition, Boot, RebuildBS, List. And if I can see my files, choose Write, confirm, Quit and reboot. But I think that I should tread lightly and not do anything too hasty without some expert advice.
Please help.
Re: I think I need a little help
The partitions seems to use only 1 Go. As you wrote you have seen your files, I assume it's normal.
Run TestDisk, Advanced, Boot, BackupBS, confirm, Quit and restart your computer.
J0ckieboy
#3 Post by J0ckieboy »
Thank you very much for your help cgrenier.
Here is what is displayed after I run TestDisk, Advanced, Boot:
Disk /dev/sde - 300 GB / 279 GiB - CHS 36481 255 63
Bad
Error: size boot_sector 586067202 > partition 2265102
Bad
First sectors (Boot code and partition information) are not identical.
Second sectors (cluster information) are not identical.
The option 'Dump' when highlighted says 'Dump boot sector and backup boot sector' but when selected it just shows this:
Boot sector                        Backup boot sector
0010 02001000 00f86317   ......c.  02000000 00f80000   ........
0018 3f00ff00 3f000000   ?...?...  3f00ff00 3f000000   ?...?...
0020 0e902200 800029f8   .."...).  02adee22 64170100   ..."d...
0028 3f7c3e54 45535444   ?|>TESTD  00000000 02000000   ........
0030 49534b20 20204641   ISK   FA  01000600 00000000   ........
0038 54313620 20200e1f   T16   ..  00000000 00000000   ........
0040 be5b7cac 22c0740b   .[|.".t.  80002964 9da00148   ..)d...H
0048 56b40ebb 0700cd10   V.......  442d4855 32202020   D-HU2
0050 5eebf032 e4cd16cd   ^..2....  20204641 54333220     FAT32
0058 19ebfe54 68697320   ...This   2020cb00 00000000     ......
0060 6973206e 6f742061   is not a  00000000 00000000   ........
0068 20626f6f 7461626c    bootabl  00000000 00000000   ........
0070 65206469 736b2e20   e disk.   00000000 00000000   ........
0078 20506c65 61736520    Please   00000000 00000000   ........
0080 696e7365 72742061   insert a  00000000 00000000   ........
0088 20626f6f 7461626c    bootabl  00000000 00000000   ........
0090 6520666c 6f707079   e floppy  00000000 00000000   ........
0098 20616e64 0d0a7072    and..pr  00000000 00000000   ........
00A0 65737320 616e7920   ess any   00000000 00000000   ........
00A8 6b657920 746f2074   key to t  00000000 00000000   ........
00B0 72792061 6761696e   ry again  00000000 00000000   ........
00B8 202e2e2e 200d0a00    ... ...  00000000 00000000   ........
00C0 00000000 00000000   ........  00000000 00000000   ........
00C8 00000000 00000000   ........  00000000 00000000   ........
00D0 00000000 00000000   ........  00000000 00000000   ........
00D8 00000000 00000000   ........  00000000 00000000   ........
00E0 00000000 00000000   ........  00000000 00000000   ........
00E8 00000000 00000000   ........  00000000 00000000   ........
00F0 00000000 00000000   ........  00000000 00000000   ........
00F8 00000000 00000000   ........  00000000 00000000   ........
0100 00000000 00000000   ........  00000000 55aa7500   ....U.u.
0108 00000000 00000000   ........  00000000 00000000   ........
 [Previous] >[  Next  ]  [  Quit  ]
How should I proceed?
J0ckieboy
#4 Post by J0ckieboy »
I could really do with some help please.
#5 Post by Fiona »
In your case, it looks like that chkdsk was already running and made changes to your file system and data.
The size of your current FAT32-partition is approximately 1 GB.
Before, did you have only one partition on your disk, using the whole space?
Did you run Deeper Search in TestDisk to have a try to find more partitions?
J0ckieboy
#6 Post by J0ckieboy »
Thanks for your reply Fiona.
There was only one partition using the whole disk.
I did run Deep Search in TestDisk and was able to see my files (I was unable to see anything with the quick search).
#7 Post by Fiona »
Would it be possible to copy and paste the content of your testdisk.log into your next post?
Also, I'd like to see, on which partition you were able to list your data?
J0ckieboy
#8 Post by J0ckieboy »
Here's the contents of my latest TeskDisk.log:
Wed Sep 11 15:24:16 2013
OS: Linux, kernel 3.8.0-26-generic (#38-Ubuntu SMP Mon Jun 17 21:43:33 UTC 2013) x86_64
Compiler: GCC 4.7
Compilation date: 2013-02-16T06:51:40
ext2fs lib: 1.42.5, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size       1953525168 sectors
/dev/sda: user_max   1953525168 sectors
/dev/sda: native_max 1953525168 sectors
/dev/sda: dco        1953525168 sectors
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10EADS-00L5B1, S/N:WD-WCAU48556773, FW:01.01A01
Disk /dev/sdd - 300 GB / 279 GiB - CHS 36481 255 63, sector size=512 - USB-HS SAMSUNG HD300LD, FW:0.01
Disk /dev/sdd - 300 GB / 279 GiB - USB-HS SAMSUNG HD300LD
Analyse Disk /dev/sdd - 300 GB / 279 GiB - CHS 36481 255 63
FAT32 at 0/1/1
test_FAT()
sector_size  512
cluster_size 1
reserved     1
fats         2
dir_entries  4096
sectors      0
media        F8
fat_length   5987
secs_track   63
heads        255
hidden       63
total_sect   2265102
Computes LBA from CHS for Disk /dev/sdd - 300 GB / 279 GiB - CHS 36482 255 63
FAT32 at 0/1/1
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 32-71555
FAT2 : 71556-143079
sectors : 586067202
cluster_size : 64
FAT32 at 0/1/7
 1 * FAT32                    0   1  1   140 254 63    2265102
In an earlier post I copied the output which showed my data. Here it is:
The list of files was longer. Would it be better to post the full list?
J0ckieboy
#9 Post by J0ckieboy »
Thanks for your help Fiona.
I have included a more complete log.
Compiler: GCC 4.7
FAT32 at 0/1/1
test_FAT()
sector_size  512
cluster_size 1
reserved     1
fats         2
dir_entries  4096
sectors      0
media        F8
fat_length   5987
secs_track   63
heads        255
hidden       63
total_sect   2265102
FAT32 at 0/1/1
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 32-71555
FAT2 : 71556-143079
sectors : 586067202
cluster_size : 64
FAT32 at 0/1/7
Analyse Disk /dev/sdd - 300 GB / 279 GiB - CHS 36482 255 63
FAT32 at 0/1/1
test_FAT()
sector_size  512
cluster_size 1
reserved     1
fats         2
dir_entries  4096
sectors      0
media        F8
fat_length   5987
secs_track   63
heads        255
hidden       63
total_sect   2265102
FAT32 at 0/1/1
FAT32 at 0/1/1
FAT32 at 0/1/7
FAT1 : 32-71555
FAT2 : 71556-143079
sectors : 586067202
cluster_size : 64
FAT32 at 0/1/7
 2223819 drwxr-xr-x     0      0         0 29-Aug-2013 23:08 Workout
  561899 -rwxr-xr-x     0      0     14336 12-Nov-2010 21:57 Thumbs.db
 2266402 -rwxr-xr-x     0      0    188416 14-Mar-2011 22:48 france trp.xls
  851970 drwxr-xr-x     0      0         0 17-Apr-2013 11:05 CD rips
X1939345 drwxr-xr-x     0      0         0 11-Dec-2010 16:14 Shrek Forever After (2010) DVD-R NTSC (eng-fre-spa) [punisher_lat
 9113634 drwxr-xr-x     0      0         0 27-Feb-2010 11:10 Software, drivers, manuals
X5308418 drwxr-xr-x     0      0         0 19-Aug-2012 22:27 movies to watch
X 579179 -rwxr-xr-x     0      0 1352314880 16-Oct-2010 16:40 _INUXM~1.ISO
 7963512 drwxr-xr-x     0      0         0  6-Sep-2008 14:51 Movies
 7963513 drwxr-xr-x     0      0         0  6-Sep-2008 14:52 Guy
X  57842 -rwxr-xr-x     0      0 733987926 30-Dec-2011 09:43 LOVE CRIME [2010] DVD Rip Xvid [StB].avi
X  43115 -rwxr-xr-x     0      0 1799392848 15-Jan-2012 18:14 The Tree of Life (2011) DVDRip XviD-MAXSPEED www.torentz.3xforum.ro.avi
X  25788 drwxr-xr-x     0      0     32768 19-Sep-2010 10:55 _EMETA~1.COM
X9016069 drwxr-xr-x     0      0         0  1-Mar-2010 18:31 Harry Brown[2009]DvDrip[Eng]-FXG
X6011904 -rwxr-xr-x     0      0 366794172 28-Feb-2010 14:39 Craig.Ferguson.2010.02.26.
X6849104 -rwxr-xr-x     0      0 292939776 28-Feb-2010 18:43 Rugby Six Nations 2010 Interactive Forum.20100227.bobuk.thebox.avi
X6866631 -rwxr-xr-x     0      0 1172380724 28-Feb-2010 20:53 2010.Vancouver.Olympics.Womens.Figure.Skating.Free.Skate.HDTV.XviD-2HD.avi
X8982245 -rwxr-xr-x     0      0 366680318  1-Mar-2010 18:24 Desperate.Housewives.S06E16.HDTV.XviD-LOL.avi
X9038468 drwxr-xr-x     0      0         0  1-Mar-2010 18:46 Armored[2009]DvDrip[Eng]-FXG
X5430045 drwxr-xr-x     0      0         0 23-Dec-2009 21:43 _500)D~1._EN
X8716290 drwxr-xr-x     0      0         0 31-Jul-2009 22:01 Desperate Housewives Season 2 Complete HDTV-soagg
X5514715 drwxr-xr-x     0      0         0 27-Feb-2010 23:09 Death Becomes Her
X9070404 -rwxr-xr-x     0      0 733060906  2-Mar-2010 07:55 2010.Vancouver.Olympics.Womens.Figure.Skating.Short.Program.HDTV.XviD-2HD.avi
X5439490 drwxr-xr-x     0      0         0  2-Jan-2009 22:24 _ARLIT~1.AR
X  12214 -rwxr-xr-x     0      0 1207231822 27-Feb-2010 21:23 2010.02.26.Six.Nations.Round.3.Wales.vs.France.x264.mp4
X  59131 drwxr-xr-x     0      0     32768 26-Jan-2010 18:51 MSI55c32.tmp
X4448650 -rwxr-xr-x     0      0 183121870  5-Nov-2008 22:15 Barack.Obama.Presidential.Victory.Speech.HDTV.XviD-XOXO.avi
X      2 drwxr-xr-x     0      0     32768  6-Dec-2009 19:19 Rugby
X4784130 drwxr-xr-x     0      0         0 23-May-2008 18:56 Breach KLAXXON
X6724095 drwxr-xr-x     0      0         0 29-Jan-2010 23:33 The Informant [2009] dvd rip nlx
X6685523 -rwxr-xr-x     0      0 367191272 29-Jan-2010 07:14 Craig.Ferguso
X6227093 drwxr-xr-x     0      0         0  6-Jan-2009 23:12 Vicky Cristina Barcelona Soundtrack [GeneGeter.com]
X4114626 drwxr-xr-x     0      0         0 31-Oct-2009 23:32 Dreamgirls[2006]DvDrip[Eng]-aXXo
X6423131 drwxr-xr-x     0      0         0  2-Jan-2010 19:00 Office 2007 Enterprise Blue Edition
X 543056 -rwxr-xr-x     0      0    365586 24-Mar-2007 19:18 mfkb_xp_ver10200.exe
X   4130 -rwxr-xr-x     0      0       162 27-Feb-2010 11:08 _$CREF~1.RTF
X6160389 drwxr-xr-x     0      0         0 15-Nov-2009 20:17 _HETAL~1.ENG
X7993416 drwxr-xr-x     0      0         0 30-Jul-2009 23:21 Desperate Housewives Season 1 Complete HDTV-soagg
X4609923 -rwxr-xr-x     0      0 735655936 31-Dec-2008 14:41 Requiem For A Dream - Directors Cut (2000).avi
X6167280 drwxr-xr-x     0      0         0 27-Feb-2010 22:53 Flo_Rida-Right_Round-(CDS)-2009
X7680965 drwxr-xr-x     0      0         0 31-Oct-2009 07:58 Aaaa bunch of stuff backed up from XP 311009
X2974849 -rwxr-xr-x     0      0 783454208 31-Oct-2009 23:39 BBC.Horizon.2009.Fix.Me.DVBC.XviD.AC3.MVGroup.org.avi
X 407988 drwxr-xr-x     0      0         0  7-Dec-2009 19:00 RegistryFix 7.1(trees)
X   1063 drwxr-xr-x     0      0     32768 25-Feb-2010 23:22 32b88062ae63d88cd71918
X8006618 -rwxr-xr-x     0      0 366661632 13-Jan-2010 20:50 _EROES~1.AVI
X7814739 drwxr-xr-x     0      0         0 17-Jan-2009 20:06 _LOOD~1.DIA
X8006591 drwxr-xr-x     0      0         0 21-Apr-2009 21:03 The Kite Runner KLAXXON
X6163841 -rwxr-xr-x     0      0   8099132 15-Nov-2009 22:10 30H!3 feat. Katy Perry - Starstrukk (Single Version).mp3
X6826952 -rwxr-xr-x     0      0 368699482 17-Apr-2008 21:23 _ATION~1.AVI
X2115866 drwxr-xr-x     0      0         0  7-Jun-2006 13:00 Over The Hedge (2006) maVen TS KvCD by Hockney(TUS Release)
X7558139 -rwxr-xr-x     0      0 735614976 10-Apr-2009 20:03 MONSTER'S.BALL.DVDRIP.D7S.avi
X6164089 drwxr-xr-x     0      0         0 27-Feb-2010 22:48 Katy Perry - One of the Boys [New Edition] v0
X8052083 drwxr-xr-x     0      0         0 30-Jan-2010 12:08 Million.Dollar.Baby[2004]DvDrip[Eng]-TB
X   2711 drwxr-xr-x     0      0     32768 25-Feb-2010 23:02 f177afd7c049843d63f2
X8967971 -rwxr-xr-x     0      0 367103000 24-Feb-2010 17:48 _4S08E~1.AVI
X8033914 drwxr-xr-x     0      0         0 15-Feb-2010 18:52 Everybody s Fine (2010)(18-3 bios) NTSC 2Lions-Team
X6333350 drwxr-xr-x     0      0         0  2-May-2009 13:59 Bridget.Jones's.Diary[2001]DvDrip[Eng.Subs]-kirklestat
X9126905 drwxr-xr-x     0      0         0  8-Sep-2009 00:24 Ally McBeal - Season 2
X8979620 drwxr-xr-x     0      0         0 25-Feb-2010 23:08 ea64fa13b8c4efa7052cda
X8982245 -rwxr-xr-x     0      0 366640244 26-Feb-2010 09:53 2010.Vancouver.Olympics.Figure.Skating.Ice.Dance.Original.Dance.HDTV.XviD-2HD.avi
X6167674 -rwxr-xr-x     0      0 737935360 16-Nov-2009 07:39 The.Brothers.Grimm.[2005].
X6796396 drwxr-xr-x     0      0         0  5-Jan-2010 21:53 The Curious Case of Benjamin Button[2008]DvDrip[Eng]-FXG
X7208962 drwxr-xr-x     0      0         0  4-Feb-2010 17:30 The Official Guide to the TOEFL iBT
X4718597 -rwxr-xr-x     0      0 183810784  1-Feb-2010 18:33 Family.Guy.S0
X4735395 -rwxr-xr-x     0      0 366916050  1-Feb-2010 21:44 Lost.S06E00.HDTV.XviD-NoTV.avi
X7238091 -rwxr-xr-x     0      0 832942080  4-Feb-2010 18:02 Precious (2009) DvdScR.[Xvid] {1337x}-X.avi
X  12215 drwxr-xr-x     0      0         0  7-Feb-2010 13:16 An Education 2009 DVDScr H264 AAC-SecretMyth (Kingdom-Release)
X  18485 drwxr-xr-x     0      0     32768 15-Feb-2010 18:50 It s Complicated (2009) NTSC Promo NL subs 2Lions-Team
X5316151 -rwxr-xr-x     0      0 365978312 17-Feb-2010 19:11 Lost.S06E04.HDTV.XviD-P0W4.avi
X6456881 -rwxr-xr-x     0      0 1094428649 10-Aug-2009 00:01 _UGBY-~1.MKV
X7077890 drwxr-xr-x     0      0         0 10-Aug-2009 23:54 Desperate Housewives Season 4 Complete HDTV XVID-soagg
X8944232 drwxr-xr-x     0      0         0  7-Sep-2009 11:58 Ally McBeal Season 1
X4036704 drwxr-xr-x     0      0         0 20-Feb-2010 11:37 Love actually (2003) [English]-MrLore
X      5 drwxr-xr-x     0      0     32768  9-Feb-2010 23:37 _SERIO~1.XVI
X6160389 drwxr-xr-x     0      0         0 12-Feb-2010 18:56 Nine.DVDSCR.XviD-NEPTUNE
X8993434 -rwxr-xr-x     0      0 575662986 26-Feb-2010 10:17 2010.Vancouver.Olympics.Figure.Skating.Ice.Dance.Free.Dance.and.Medal.Presentation.HDTV.XviD-2HD.avi
X9011002 -rwxr-xr-x     0      0 575801272 26-Feb-2010 09:55 2010.Vancouver.Olympics.Figure.Skating.Ice.Dance.Compulsory.Dance.HDTV.XviD-2HD.avi
X9048040 -rwxr-xr-x     0      0 732734298 26-Feb-2010 12:11 2010.Vancouver.Olympics.Figure.Skating.Pairs.Short.Program.HDTV.XviD-2HD.avi
X7509025 -rwxr-xr-x     0      0 780607488 18-Jul-2008 18:57 National.Geographic.Naked.Science.Birth.of.America.DVB.Xvid.mp3.www.mvgroup.org.avi
X7274498 -rwxr-xr-x     0      0 779867914 19-Jul-2008 17:39 National.Geographic.The.Living.Edens.14of24.Thailand.DVB.x264.AAC.www.mvgroup.org.mkv
X4235388 -rwxr-xr-x     0      0 369543626  2-Sep-2008 20:37 Prison.Break.S04E01.PROPER.HDTV.XviD-2HD.[VTV].avi
X4718594 drwxr-xr-x     0      0         0  6-Jul-2006 07:15 Syriana[2005].DvDrip[Eng]-aXXo
X7289466 -rwxr-xr-x     0      0 780488704 19-Jul-2008 16:27 National.Geographic.The.Hunt.for.Hitlers.Scientists.DVB.Xvid.mp3.www.mvgroup.org.avi
X5439492 drwxr-xr-x     0      0         0 22-Aug-2008 16:08 The Other Boleyn Girl 2008 DVDRip H264-KingBen (Kingdom-Release)
X5781276 -rwxr-xr-x     0      0 366517168 24-Aug-2008 21:30 Beijing.2008.Rhythmic.Gymnastics.Womens.Individual.All-Around.Final.HDTV.XviD-XOXO.avi
X5792462 -rwxr-xr-x     0      0 365402102 24-Aug-2008 21:55 Beijing.2008.Team.Synchronized.Swimming.Final.HDTV.XviD-XOXO.avi
X3290573 -rwxr-xr-x     0      0 214392061 26-Aug-2008 21:40 Beijing.2008.Olympic.Rhythmic.Gymnastics.group.final.x264-sailo1.mkv
X4246666 -rwxr-xr-x     0      0 368073050  2-Sep-2008 21:10 Prison.Break.S04E02.PROPER.HDTV.XviD-2HD.[VTV].avi
X4257899 -rwxr-xr-x     0      0 782675780  3-Sep-2008 01:16 BBC.Black.Power.Salute.2008.WS.PDTV.XviD.MP3.MVGroup.org.avi
X6440051 -rwxr-xr-x     0      0   8931438 23-Jul-2006 19:43 Ali G interviews a porn st
X6440324 drwxr-xr-x     0      0         0 23-Jul-2006 19:30 Da.Ali.G.Show.Season1.DVDRip.XviD
X6484958 drwxr-xr-x     0      0         0 25-Jul-2006 18:10 Ali g Show Season 2
X6517416 drwxr-xr-x     0      0         0 29-Jul-2006 07:58 The Importance Of Being Earnest 2002 DVDRip kvcd Jamgood(TUS Release)
X1966082 drwxr-xr-x     0      0         0 28-Aug-2006 19:07 My Documents
X  22482 drwxr-xr-x     0      0     32768 28-Aug-2006 21:23 Sopranos Series 1
X1380915 drwxr-xr-x     0      0         0 27-Mar-2006 22:01 prison break S2
X   1398 drwxr-xr-x     0      0     32768  5-Sep-2006 18:04 MSI9b0a5.tmp
X6588593 -rwxr-xr-x     0      0  16761742  5-Sep-2006 22:30 psycho_girl.wmv
X6589105 drwxr-xr-x     0      0         0  5-Sep-2006 22:23 Webcam del 1
X6595512 drwxr-xr-x     0      0         0  5-Sep-2006 22:25 MSN webcam masturbation
X1966082 drwxr-xr-x     0      0         0 28-Aug-2006 19:07 the human stain
X      7 drwxr-xr-x     0      0     32768 27-Sep-2006 20:16 Alexander
X  62354 drwxr-xr-x     0      0     32768 27-Sep-2006 20:17 Alejandro Magno Edicion Especial DVD1
X5925968 -rwxr-xr-x     0      0 417494980 28-Sep-2006 03:30 Exercise - Yoga - 40 minutes workout - Yoga zone.mpg
X  51613 drwxr-xr-x     0      0     32768  4-Oct-2006 03:11 MSI81ec0.tmp
X      7 drwxr-xr-x     0      0     32768  5-Oct-2006 03:02 MSI215c1.tmp
X     11 drwxr-xr-x     0      0     32768  5-Oct-2006 03:06 MSI215d4.tmp
X     11 drwxr-xr-x     0      0     32768  5-Oct-2006 03:07 MSI215e9.tmp
X     11 drwxr-xr-x     0      0     32768  5-Oct-2006 03:08 MSI2160d.tmp
X     11 drwxr-xr-x     0      0     32768  5-Oct-2006 03:09 _SI21620.TMP
X1835019 drwxr-xr-x     0      0         0  6-Oct-2006 17:38 The Apartment
X1856432 drwxr-xr-x     0      0         0  6-Oct-2006 17:40 Ray.DVDRip.XviD-2005
X  57521 drwxr-xr-x     0      0     32768 10-Oct-2006 12:59 Family Guy
X  55227 drwxr-xr-x     0      0     32768 14-Oct-2006 03:06 _368715_
X  55227 drwxr-xr-x     0      0     32768 14-Oct-2006 03:06 e893dec2646e61dbc7
X  55227 drwxr-xr-x     0      0     32768 14-Oct-2006 03:09 _SI19604.TMP
X  55227 drwxr-xr-x     0      0     32768 14-Oct-2006 03:11 _SI19617.TMP
X  55227 drwxr-xr-x     0      0     32768 14-Oct-2006 03:14 MSI1962a.tmp
X  55227 drwxr-xr-x     0      0     32768 14-Oct-2006 03:15 MSI1963d.tmp
X  55230 drwxr-xr-x     0      0     32768 15-Oct-2006 03:08 MSI7146f.tmp
X  55232 drwxr-xr-x     0      0     32768 15-Oct-2006 03:12 _SI71482.TMP
X  11131 drwxr-xr-x     0      0     32768 30-Oct-2006 18:13 Little.Man.2006.NTSC.DVDR-XPDVD[www.moviex.info]
X6821415 drwxr-xr-x     0      0         0 30-Oct-2006 18:14 Pirates.of.the.Caribbean.Dead.Mans.Chest.2006.PROPER.DVDRIP.XviD-ABSTINENCE[www.moviex.info]
X6866630 drwxr-xr-x     0      0         0 30-Oct-2006 18:18 Lost.S03E01.HDTV.XviD-XOR
X6877795 drwxr-xr-x     0      0         0 31-Oct-2006 07:22 Lost.S03E02.HDTV.XviD-XOR_PT-BR
X6888969 drwxr-xr-x     0      0         0 31-Oct-2006 07:24 Lost.S03E03.HDTV.XviD-LOL_PT-BR
X  21491 drwxr-xr-x     0      0     32768  8-Nov-2006 03:18 MSI2b45a.tmp
X  21493 drwxr-xr-x     0      0     32768  8-Nov-2006 03:18 MSI2b45e.tmp
X  21493 drwxr-xr-x     0      0     32768  8-Nov-2006 03:21 MSI2b481.tmp
X  21493 drwxr-xr-x     0      0     32768  8-Nov-2006 03:21 MSI2b48a.tmp
X  21493 drwxr-xr-x     0      0     32768  8-Nov-2006 03:21 MSI2b490.tmp
X  21493 drwxr-xr-x     0      0     32768  8-Nov-2006 03:21 MSI2b499.tmp
X  21493 drwxr-xr-x     0      0     32768  8-Nov-2006 03:21 MSI2b49f.tmp
X  21493 drwxr-xr-x     0      0     32768  8-Nov-2006 03:21 MSI2b4a8.tmp
X  21493 drwxr-xr-x     0      0     32768  8-Nov-2006 03:22 MSI2b4ae.tmp
X5520630 drwxr-xr-x     0      0         0 26-Nov-2006 22:14 Borat XViD
X  37522 drwxr-xr-x     0      0     32768 26-Nov-2006 22:17 Borat PSP
X5542546 drwxr-xr-x     0      0         0 27-Nov-2006 01:15 Mad TV
X  15877 drwxr-xr-x     0      0     32768 27-Nov-2006 02:57 Mad TV season 12 ep.01
X6673127 drwxr-xr-x     0      0         0 27-Nov-2006 07:32 Borat.TS.XViD-DiNATY.[www.torrentfive.com]
X6703752 drwxr-xr-x     0      0         0 30-Nov-2006 19:24 MADtv.S12E04.PDTV.XviD-KiNGDOM
X6758234 drwxr-xr-x     0      0         0 30-Nov-2006 20:19 Season 3 - Interns
X6004728 -rwxr-xr-x     0      0 367426018  1-Dec-2006 23:36 Survivor.S13E12.You.Are.A.Rat.PDTV.XviD-FQM.avi
X6027128 drwxr-xr-x     0      0         0  3-Dec-2006 00:48 American Dad! Season1 (XviD asd) EnglishV+NapisyPL
X6071005 drwxr-xr-x     0      0         0  3-Dec-2006 22:24 Rugby 2006 Wallabies Vs Ireland 19-11-06
X      3 drwxr-xr-x     0      0     32768  5-Dec-2006 18:50 _CYCLE~1
X7329319 drwxr-xr-x     0      0         0  7-Dec-2006 19:31 South.Park.S10.COMPLETE
X7400639 -rwxr-xr-x     0      0 208998400 12-Dec-2006 11:14 The.Simple.Life.S04E01.XviD-LionsDen.avi
X7407018 -rwxr-xr-x     0      0 182833152 12-Dec-2006 11:50 The.Simple.Life.S04E02.DSR.XviD-UMD.avi
X7412598 -rwxr-xr-x     0      0 183189504 12-Dec-2006 19:23 The.Simple.Life.S04E03.DSR.XviD-UMD.avi
X7418189 -rwxr-xr-x     0      0 182970368 13-Dec-2006 06:09 The.Simple.Life.S04E04.DSR.XviD-UMD.avi
X7423773 drwxr-xr-x     0      0         0 12-Dec-2006 18:23 The Simple Life 4 - Episode 5 - The Bowden Family
X7496722 -rwxr-xr-x     0      0 182794240 15-Dec-2006 06:33 The.Simple.Life.S04E09.DSR.XviD-THOR.avi
X7502301 -rwxr-xr-x     0      0 193177600 15-Dec-2006 05:09 the.simple.life.til.death.do.us.part.s04ep07.divx.[kyleinct].avi
X7508197 drwxr-xr-x     0      0         0 14-Dec-2006 16:45 the.simple.life.s04e08.beggs.family.xvid-reb
X  48664 drwxr-xr-x     0      0     32768 16-Dec-2006 03:08 _541699_
X  48666 drwxr-xr-x     0      0     32768 16-Dec-2006 03:08 a7d719442a8acdeb7d3487e7ecaa62ad
X  48666 drwxr-xr-x     0      0     32768 16-Dec-2006 03:16 MSI90aee.tmp
X5784400 drwxr-xr-x     0      0         0 19-Dec-2006 00:31 South Park Season 9
X5815079 -rwxr-xr-x     0      0 386143140 19-Dec-2006 23:37 A Girls Guide To 21st Century Sex 1 of 8 [XviD] - DaRmEtH.avi
X5826864 drwxr-xr-x     0      0         0 19-Dec-2006 21:25 _Vしい~1
X5826864 drwxr-xr-x     0      0         0 19-Dec-2006 21:25 A Girls Guide To 21st Century Sex
X5850408 -rwxr-xr-x     0      0 386152842 20-Dec-2006 03:21 A Girls Guide To 21st Century Sex 4 of 8 [XviD] - DaRmEtH.avi
X5862193 -rwxr-xr-x     0      0 386231382 20-Dec-2006 07:21 A Girls Guide To 21st Century Sex 5 of 8 [XviD] - DaRmEtH.avi
X5897466 drwxr-xr-x     0      0         0 24-Dec-2006 22:00 Flags Of Our Fathers (2006) NEPTUNE DVDSCR KvCD Hockney(TUS Release)
X  63404 drwxr-xr-x     0      0     32768 27-Dec-2006 06:42 Southpark Season 8
X      5 drwxr-xr-x     0      0     32768 14-Jan-2007 21:20 When Harry Met Sally (1989)
X7768240 drwxr-xr-x     0      0         0 15-Jan-2007 00:27 Untold Stories of World War II
X  55762 drwxr-xr-x     0      0     32768 15-Jan-2007 03:03 _SI8352.TMP
X7789012 -rwxr-xr-x     0      0 366989716 15-Jan-2007 22:18 24.s06e01.hdtv.xvid-xor.[VTV].avi
X7800212 -rwxr-xr-x     0      0 366987446 15-Jan-2007 18:21 24.s06e02.hdtv.xvid-xor.[VTV].avi
X7811412 -rwxr-xr-x     0      0 369627136 15-Jan-2007 22:12 24.S06E02.7AM.TO.8AM.DVDRip.XviD-MEMETiC.avi
X7822693 drwxr-xr-x     0      0         0 15-Jan-2007 22:44 24 Season 6
X7602178 drwxr-xr-x     0      0         0  5-Feb-2007 01:19 Six.Nations.2007.England.vs.Scotland.03feb07.Xvid
X  43323 drwxr-xr-x     0      0     32768  5-Feb-2007 02:09 _VGQT.DAT
X  43323 drwxr-xr-x     0      0     32768  5-Feb-2007 02:09 _VG7DB_F.DAT
X  43323 drwxr-xr-x     0      0     32768  5-Feb-2007 02:09 _VG7DB_N.DAT
X  43323 drwxr-xr-x     0      0     32768  5-Feb-2007 02:09 _VG7DB_R.DAT
X  43323 drwxr-xr-x     0      0     32768  5-Feb-2007 02:09 _VG7QT.DAT
X  22607 drwxr-xr-x     0      0     32768  5-Feb-2007 09:42 Six.Nations.2007.England.vs.Scotland.03feb07.Xvid
X   1891 drwxr-xr-x     0      0     32768  5-Feb-2007 14:04 Six.Nations.2007.England.vs.Scotland.03feb07.Xvid
X  22380 drwxr-xr-x     0      0     32768  8-Feb-2007 20:00 Ugly Betty
X  33651 drwxr-xr-x     0      0     32768  1-Mar-2007 08:02 Happy.Feet.REPACK.DVDSCR.DVDR-TGP
X2359298 drwxr-xr-x     0      0         0  6-Mar-2007 22:05 The Queen
X2413176 drwxr-xr-x     0      0         0  7-Mar-2007 23:22 Seinfeld Sea1
X  17482 drwxr-xr-x     0      0     32768 15-Mar-2007 03:07 MSI3b211.tmp
X  17484 drwxr-xr-x     0      0     32768 15-Mar-2007 03:11 _054278_
X  17484 drwxr-xr-x     0      0     32768 15-Mar-2007 03:11 258f05f71c2fb6b9348d70c8702c
X1610067 drwxr-xr-x     0      0         0 15-Mar-2007 20:47 United 93 2006 DvDrip Eng
X  59458 drwxr-xr-x     0      0     32768 16-Mar-2007 00:56 United.93[2006]DvDrip[Eng]-aXXo
X5343386 -rwxr-xr-x     0      0 366602240 21-Mar-2007 03:21 24.S06E14.HDTV.XviD-LOL.avi
X   9551 drwxr-xr-x     0      0     32768 21-Mar-2007 12:55 MSI440e0.tmp
X   9557 drwxr-xr-x     0      0     32768 21-Mar-2007 13:00 MSI8e146.tmp
X   9560 drwxr-xr-x     0      0     32768 21-Mar-2007 13:01 MSI9bc61.tmp
X  20725 drwxr-xr-x     0      0     32768 21-Mar-2007 14:16 MSI1da77.tmp
X  20728 drwxr-xr-x     0      0     32768 21-Mar-2007 14:20 MSI4c5e8.tmp
X  28059 drwxr-xr-x     0      0     32768 12-Apr-2007 03:04 MSIa9dd3.tmp
X8296825 drwxr-xr-x     0      0         0 12-Apr-2007 20:51 The.Devil.Wears.Prada[2006]DvDrip[Eng]-aXXo
X2963682 drwxr-xr-x     0      0         0 13-May-2006 09:41 Brokeback.Mountain[2005]DvDrip[Eng]-aXXo
X  61718 drwxr-xr-x     0      0     32768 13-Apr-2007 03:03 _724623_
X  61720 drwxr-xr-x     0      0     32768 13-Apr-2007 03:03 d13326583373827e07ec
X8006617 drwxr-xr-x     0      0         0 21-Apr-2007 21:04 The.Illusionist[2006]DvDrip[Eng]-aXXo
X  14802 drwxr-xr-x     0      0     32768 25-Apr-2007 00:06 MSI375b9.tmp
X  14804 drwxr-xr-x     0      0     32768 25-Apr-2007 00:07 MSI4d7dd.tmp
X8334267 -rwxr-xr-x     0      0 363104256  2-May-2007 13:29 The.Sopranos.S06E16.HDTV.XviD-LOL.avi
X  22277 drwxr-xr-x     0      0     32768  2-May-2007 16:28 MSIde518.tmp
X  22280 drwxr-xr-x     0      0     32768  2-May-2007 16:33 _SI6644.TMP
X  22283 drwxr-xr-x     0      0     32768  2-May-2007 17:56 MSIef989.tmp
X8350948 -rwxr-xr-x     0      0 366606048  3-May-2007 23:14 Lost.S03E19.HDTV.XviD-XOR.avi
X8388610 -rwxr-xr-x     0      0 691305472  5-May-2007 14:20 Pulp Fiction.avi
X  21099 drwxr-xr-x     0      0     32768  5-May-2007 13:24 Hot.Fuzz.R5.LINE.XViD-PUKKA
X  43998 drwxr-xr-x     0      0     32768  5-May-2007 19:58 _SI45041.TMP
X8432606 drwxr-xr-x     0      0         0  5-May-2007 21:17 Hot Fuzz (2007) PUKKA R5 DVDRiP KvCD Hockney(TUS Release)
X8519682 -rwxr-xr-x     0      0 368793600  7-May-2007 14:29 The.Sopranos.S06E17.HDTV.XviD-LOL.avi
X1540774 -rwxr-xr-x     0      0 367212544 14-May-2007 18:58 The.Sopranos.S06E18.HDTV.XviD-LOL.avi
X8620443 -rwxr-xr-x     0      0 366319522 21-May-2007 19:28 The.Sopranos.S06E19.HDTV.XviD-NoTV.avi
X      2 -rwxr-xr-x     0      0      1368 23-May-2007 20:28 _OOTEX.LOG
X  22445 drwxr-xr-x     0      0     32768 27-May-2007 20:43 Arg V Ire 26th May '07
X5105681 -rwxr-xr-x     0      0 1051236275 27-May-2007 21:55 Rugby.Union.Australia.vs.Wales.26th.May.2007.PDTV.x264.mp4
X8650754 -rwxr-xr-x     0      0 695296000 27-May-2007 01:47 Clerks.avi
X8671973 drwxr-xr-x     0      0         0 27-May-2007 21:55 Pirates of the Caribbean At Worlds End (2007) mVs TELESYNC KvCD Hockney(TUS Release)
X  47177 -rwxr-xr-x     0      0  28119040 28-May-2007 10:37 Chuck.Liddell.vs.Quinton.Jackson.avi
X  47177 drwxr-xr-x     0      0     32768 28-May-2007 18:05 South Africa vs England 1  27.05.07 1st Test.divx
X  21107 drwxr-xr-x     0      0     32768  2-Jun-2007 03:02 MSI6b50c.tmp
X  21109 drwxr-xr-x     0      0     32768  2-Jun-2007 03:02 MSI6b510.tmp
X  21109 drwxr-xr-x     0      0     32768  2-Jun-2007 03:03 _517439_
X  21109 drwxr-xr-x     0      0     32768  2-Jun-2007 03:03 bc2f17421670a052df54bde014
X5505029 drwxr-xr-x     0      0         0 10-Jun-2007 20:02 Latcho Drom
X5552811 drwxr-xr-x     0      0         0 10-Jun-2007 20:03 Fila Brazillia
X 533253 -rwxr-xr-x     0      0   4286719 11-Mar-2007 18:07 02  Gnarls Barkley - Crazy.mp3
X5557420 -rwxr-xr-x     0      0 372371456 10-Feb-2007 23:24 Total Immersion Freestyle [xvid].avi
X5569804 drwxr-xr-x     0      0         0 10-Jun-2007 20:04 Louis Theroux - The Most Hated Family in America (01-04-07 BBC2)
 1544074 drwxr-xr-x     0      0         0 10-Jun-2007 20:07 Music
X1782368 -rwxr-xr-x     0      0    240289 13-Oct-2006 21:10 _UY.JPG
X1782376 -rwxr-xr-x     0      0        81 21-Aug-2006 20:12 Guy菴乗園.txt
X1782377 -rwxr-xr-x     0      0      1306 20-Aug-2006 01:49 From Guy to Brad.txt
X1814444 drwxr-xr-x     0      0         0 10-Jun-2007 20:16 Games
X1832925 drwxr-xr-x     0      0         0 10-Jun-2007 20:17 The Dining Rooms
X 515544 -rwxr-xr-x     0      0     89201 12-Nov-2004 23:02 NEC Refreshed PC繧偵#雉シ蜈・縺輔l縺溘♀螳「讒倥∈.rtf
X2416933 drwxr-xr-x     0      0         0 10-Jun-2007 22:08 Schindler�エs List
X5959355 drwxr-xr-x     0      0         0 14-Dec-2008 21:26 _武�007
X  60623 drwxr-xr-x     0      0     32768 10-Jun-2007 22:27 Keyboard and touchpad drivers
X8449266 drwxr-xr-x     0      0         0 10-Jun-2007 22:28 _ANUAL
X8450045 drwxr-xr-x     0      0         0 10-Jun-2007 22:28 Necread
X8525801 drwxr-xr-x     0      0         0 10-Jun-2007 22:34 Destinys Child - #1's (2005) - R&B [www.torrentazos.com]
X8528479 drwxr-xr-x     0      0         0 10-Jun-2007 22:35 NOW Thats What I Call Music! 20
X8571136 drwxr-xr-x     0      0         0 10-Jun-2007 22:36 Contents of D drive
X4871951 dr-xr-xr-x     0      0         0 11-Jun-2007 20:48 _PSETUP
X4884174 drwxr-xr-x     0      0         0 11-Jun-2007 20:51 _NP
X      6 drwxr-xr-x     0      0     32768 14-Jun-2007 03:00 _254554_
X      6 drwxr-xr-x     0      0     32768 14-Jun-2007 03:00 b9e7f0ee7edd27312de2
X      9 drwxr-xr-x     0      0     32768 15-Jun-2007 01:13 MSI8bb5d.tmp
X     26 drwxr-xr-x     0      0     32768 12-Jul-2007 03:01 _917103_
X5832761 -rwxr-xr-x     0      0 1177839175  9-Sep-2007 17:05 2007.09.08.RWC.04.Pool.B.England.vs.USA.SDTV.x264.mp4
X5868706 -rwxr-xr-x     0      0 1539692048  9-Sep-2007 19:47 2007.09.08.RWC.03.Pool.B.Australia.vs.Japan.HDTV.x264.mp4
X  17454 drwxr-xr-x     0      0     32768  9-Sep-2007 11:26 MSIea5a1.tmp
X7095345 drwxr-xr-x     0      0         0  9-Sep-2007 15:55 Sicko.DVDSCR.XviD-CANALSTREET
X  40026 drwxr-xr-x     0      0     32768  9-Sep-2007 16:14 Ali.G.In.Da.House.SWESUB.DvdRip.Xvid - Visionmercer
X7140354 -rwxr-xr-x     0      0 733661184 15-Sep-2007 10:28 Ali G IndaHouse.avi
X7162746 -rwxr-xr-x     0      0 735025152  5-Sep-2007 22:51 Grindhouse-Death.Proof[2007][Unrated.Editon]DvDrip[Eng]-aXXo.avi
X      8 drwxr-xr-x     0      0     32768 15-Sep-2007 10:18 MSIb3cab.tmp
X     10 drwxr-xr-x     0      0     32768 15-Sep-2007 10:20 MSIb3caf.tmp
X     10 drwxr-xr-x     0      0     32768 15-Sep-2007 10:22 MSIb3cfc.tmp
X     10 drwxr-xr-x     0      0     32768 15-Sep-2007 10:24 MSIb3d03.tmp
X     10 drwxr-xr-x     0      0     32768 15-Sep-2007 10:25 MSIb3d07.tmp
X     10 drwxr-xr-x     0      0     32768 15-Sep-2007 10:31 MSIb3f33.tmp
X     10 drwxr-xr-x     0      0     32768 15-Sep-2007 10:33 MSIb3f38.tmp
X7208970 -rwxr-xr-x     0      0 1245869273 16-Sep-2007 03:53 2007.09.14.RWC.13.Pool.A.England.vs.South.Africa.HDTV.x264.mp4
X4464449 drwxr-xr-x     0      0         0 16-Sep-2007 09:29 The Beach (2000) [English Spoken & Subtitles]
X4491188 -rwxr-xr-x     0      0 525217942 17-Sep-2007 00:34 2007.09.15.RWC.15.Pool.B.Wales.vs.Australia.1st.half.mp4
X 469256 -rwxr-xr-x     0      0 525494821 17-Sep-2007 00:43 2007.09.15.RWC.15.Pool.B.Wales.vs.Australia.2nd.half.mp4
X      2 -rwxr-xr-x     0      0      1370 18-Sep-2007 06:43 _OOTEX.LOG
X7143426 -rwxr-xr-x     0      0 364698538 19-Sep-2007 08:59 Prison.Break.S03E01.HDTV.XviD-XOR.avi
X  33516 drwxr-xr-x     0      0     32768 21-Sep-2007 21:23 South Park Season 7
X7964707 -rwxr-xr-x     0      0 1180750974 29-Sep-2007 14:30 2007.09.28.RWC.33.Pool.A.England.V.Tonga.HQ.mp4
X2589728 -rwxr-xr-x     0      0 367057332 29-Sep-2007 21:31 CSI.S08E01.HDTV.XviD-XOR.avi
X2600930 -rwxr-xr-x     0      0 183558144 29-Sep-2007 20:45 the.daily.show.09.27.07.dsr.xvid-sys.[VTV].avi
X2606532 -rwxr-xr-x     0      0 183076864 29-Sep-2007 20:36 the.colbert.report.09.27.07.dsr.xvid-sys.[VTV].avi
X2612120 -rwxr-xr-x     0      0 366906514 29-Sep-2007 21:12 The.Office.S04E01.HDTV.XviD-XOR.avi
X2787903 -rwxr-xr-x     0      0 367085442 29-Sep-2007 22:47 CSI.NY.S04E01.HDTV.XviD-XOR.avi
X4194306 drwxr-xr-x     0      0         0 29-Sep-2007 19:08 New Folder
X4194306 drwxr-xr-x     0      0         0 29-Sep-2007 19:08 Prison Break s3
X4205519 drwxr-xr-x     0      0         0 29-Sep-2007 19:10 New Folder
X4205519 drwxr-xr-x     0      0         0 29-Sep-2007 19:10 Curb your Enthusiasm s6
X4212964 drwxr-xr-x     0      0         0 29-Sep-2007 19:11 Family Guy s6
X7154558 drwxr-xr-x     0      0         0 30-Sep-2007 18:45 Live.Free.Or.Die.Hard[2007]DvDrip[Eng]-aXXo
X7160283 drwxr-xr-x     0      0         0 30-Sep-2007 18:47 You.Kill.Me[2007]DvDrip.AC3[Eng]-aXXo
X8649282 -rwxr-xr-x     0      0 244016554 30-S
#10 Post by Fiona »
In your last post, the content of your partition is far beyond the limit of that small 1 Gig partition!
Did you use testdisk/undelete to list your files?
Did you have a try to copy some large files off to another disk/partition?
