I'm using v6.13 for mac. I am trying to recover .cr2 canon raw files. It seems to be recovering the files because I can see the thumbnails in the destination folder but it would disappear within a few seconds and what is left in the recup_dir folder are files with .apple, .gz. I've attached a screenshot so you can see what I mean. Please advice. Thank you.
Help with recovering from CF card Topic is solved
- Screen shot 2012-04-03 at 11.29.17 AM.png (106.65 KiB) Viewed 7565 times
Re: Help with recovering from CF card
Please use TestDisk 6.14!
It's already known, that files could disappear.
http://forum.cgsecurity.org/phpBB3/post ... canon#p894
From reading previous topics, I downloaded v6.14 and that seemed to work. At least for what I was trying to recover (Canon raw .cr2). Thumbnails did not disappear as it did in V6.13. For anyone experiencing the same problem, I suggest to go straight to V6.14. Thank you PhotoRec!
Thank you for your feedback!
I'll set your topic as solved.
