64gb Drive no luck yet with recovery
bwendo
#1 Post by bwendo »
Hi, I have been reading through the threads and have followed some instructions but I am getting stuck at some point - here is the log (I think) do you have any suggestions.
I was getting stuck at the
"partition sector doesn't have the endmark 0xAA55"
initally and have struggled to get a foothold since...
Any suggestions would be appreciated...
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=67108864
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=481747296256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2575794176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=67108864
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HDS721050CLA, S/N:JPB570HF0BXRED, FW:JP2O
Disk /dev/sdg - 67 MB / 64 MiB - CHS 8 255 63, sector size=512 - SanDisk Firebird, FW:1.05
Drive D: - 2575 MB / 2456 MiB - CHS 614 64 32, sector size=2048 - ATAPI DVD A DH16AASH, FW:SA15
Disk /dev/sdg - 67 MB / 64 MiB - SanDisk Firebird
Analyse Disk /dev/sdg - 67 MB / 64 MiB - CHS 8 255 63
file_pread(5,13,buffer,131074(8/40/35)) lseek err Invalid argument
file_pread(5,1,buffer,131074(8/40/35)) lseek err Invalid argument
file_pread(5,8,buffer,131079(8/40/40)) lseek err Invalid argument
file_pread(5,3,buffer,131087(8/40/48)) lseek err Invalid argument
file_pread(5,3,buffer,131134(8/41/32)) lseek err Invalid argument
file_pread(5,8,buffer,131150(8/41/48)) lseek err Invalid argument
file_pread(5,11,buffer,131197(8/42/32)) lseek err Invalid argument
file_pread(5,2,buffer,133119(8/73/1)) lseek err Invalid argument
file_pread(5,13,buffer,131075(8/40/36)) lseek err Invalid argument
file_pread(5,1,buffer,131090(8/40/51)) lseek err Invalid argument
file_pread(5,1,buffer,131137(8/41/35)) lseek err Invalid argument
file_pread(5,1,buffer,131158(8/41/56)) lseek err Invalid argument
file_pread(5,1,buffer,131208(8/42/43)) lseek err Invalid argument
file_pread(5,1,buffer,133121(8/73/3)) lseek err Invalid argument
Change partition type:
Sys=9B 0 0 1 7 254 63 128520
Store new MBR code
New options :
Dump : No
Align partition: Yes
Expert mode : No
Store new MBR code
A new copy of MBR code has been written.
You have to reboot for the change to take effect.
interface_load
Store new MBR code
Re: 64gb Drive no luck yet with recovery
Is it a 64 Go (your message title) or 64 Mo (testdisk.log) ?
If the correct capacity is 64 Mo, try partition type None, Advanced, Type FAT32, Boot, RebuildBS, List, Write and confirm if you can see your files. You can also try PhotoRec to recover your data.
