Vista home contents of sda1 = 582 GB of 750 GB disappeared
halfbrain
Location: Metropolregion Stuttgart, dort wo der Stuttgart21-Halbschrägtief-Lügenbahnhof gebaut werden soll
#1 Post by halfbrain »
[this is being wrote on my emergency-win98-pc from 1997 - win98 lives!]
Hello all together,
I promise openly: I will donate, if possible by paypal, if help will help ;) .
Well, my problem started one morning, when on my HP Pavilion with Vista home (32bit) on it's first, the original system-750GB-drive an automatic-win-vista-update ran.
After the update and reboot of the system, the system no longer ran.
Than after somehow muddling with the HP repair console, the system still wouldn't restart again.
Whereas an important part of my data is still accessible on sdb1 to sdb7 (2TB) it is not including extremely import emails and special bank-access-data, that are on the first 750GB-drive, because I had not yet changed the path to have both of them as well on the 2TB-Drive.
So, my problems seems to be on sda1 (582 GB). Meanwhile I secured this 582 GB bit by bit as iso on a 3TB-disk with ddrescue by Antonio in a 7h session.
The data from sda2 and sda3 seem still to be one the 750-gb-system-drive.
Here is the latest testdisk.log:
OS: Linux, kernel 3.9.6 (#25 SMP PREEMPT Sat Jun 15 15:27:01 CEST 2013) i686
Compiler: GCC 4.7
Compilation date: 2012-12-16T16:55:56
ext2fs lib: 1.41.12, ntfs lib: libntfs-3g, reiserfs lib: 0.3.0.4, ewf lib: 20100226
User is not root!
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512 - ST3750640AS, S/N:5QD3G4RL, FW:3.CHN
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DL003-9VT166, S/N:5YD7HR83, FW:CC3C
Disk /dev/sr1 - 4111 MB / 3921 MiB - 2007568 sectors (RO), sector size=2048 - TSSTcorpDVD-ROM TS-H353B, FW:HP06
Disk /dev/sda - 750 GB / 698 GiB - ST3750640AS
Analyse Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63
NTFS at 0/1/1
NTFS at 70760/185/18
NTFS at 89883/0/1
Info: size boot_sector 21173669, partition 21173670
get_geometry_from_list_part_aux head=255 nbr=3
1 P HPFS - NTFS 0 1 1 70760 174 29 1136770328
2 P HPFS - NTFS 70760 185 18 89882 233 15 307197952 [erziehungswiss]
3 * HPFS - NTFS 89883 0 1 91200 254 63 21173670 [sysschutz]
NTFS at 0/1/1
filesystem size 1136770328
mftmirr_lcn 71048145
NTFS, blocksize=4096, 582 GB / 542 GiB
filesystem size 307197952
mftmirr_lcn 19199871
NTFS, blocksize=4096, 157 GB / 146 GiB
NTFS at 89883/0/1
filesystem size 21173669
mft_lcn 170152
mftmirr_lcn 255229
HPFS - NTFS 89883 0 1 91200 254 62 21173669 [sysschutz]
NTFS, blocksize=4096, 10 GB / 10 GiB
NTFS at 91201/0/1
filesystem size 5087
mft_lcn 317
mftmirr_lcn 607
NTFS: Can't read MFT
HPFS - NTFS 91201 0 1 91201 80 47 5087
NTFS, blocksize=4096, 2604 KB / 2543 KiB
HPFS - NTFS 0 1 1 70760 254 63 1136775402
P HPFS - NTFS 91201 0 1 91201 254 63 16065
NTFS, blocksize=4096, 8225 KB / 8032 KiB
NTFS Volume is dirty.
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 16-May-2013 11:29 .
5 dr-xr-xr-x 0 0 0 16-May-2013 11:29 ..
1 * HPFS - NTFS 89883 0 1 91200 254 63 21173670 [sysschutz]
2 P HPFS - NTFS 91201 0 1 91201 254 63 16065
NTFS at 0/1/1
BAD_RS LBA=4186989146 15539560
FAT16 <32M 260628 5 12 310751 35 61 805227935
This partition ends after the disk limits. (start=4186989146, size=805227935, end=697249784, disk end=1465149168)
NTFS at 89882/233/15
NTFS found using backup sector, blocksize=4096, 157 GB / 146 GiB
NTFS at 89882/254/63
filesystem size 1443970332
mftmirr_lcn 6555520
HPFS - NTFS 0 1 1 89882 254 63 1443970332
NTFS found using backup sector, blocksize=4096, 739 GB / 688 GiB
NTFS at 89883/0/1
mft_lcn 170152
mftmirr_lcn 255229
NTFS at 91201/0/1
mft_lcn 317
mftmirr_lcn 607
The harddisk (750 GB / 698 GiB) seems too small! (< 2556 GB / 2380 GiB)
TestDisk exited normally .
By the way, I changed absolutely nothing on the pc since the system crash!
Has any of you guys out there in the wild wild world any hints or ideas, how I could get the system again running recuperating my disappeared data and programms on C:\ = 750-gb-system-drive?
Life can be so hard
Best regards
Re: Vista home contents of sda1 = 582 GB of 750 GB disappear
Try TestDisk, Advanced, select the NTFS partition,Undelete. If it failed to recover your files, you can always try PhotoRec. Be careful to not store the recovered files on this partition.
