Bad MFT, Trying on Image
bujen
#1 Post by bujen »
A 1TB WD disk, couldn't access anything on it. It had one partition only. Initial TestDisk check found bad MFT but could not repair it. Then I backed up and tried to recover the partiaion with ddrescue. But now the image shows different partition structure.
$ sudo fdisk -l
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Disk identifier: 0x70712382
Device Boot Start End Blocks Id System
/dev/sda1 * 63 1953520064 976760001 7 HPFS/NTFS/exFAT
Checking with TestDisk:
$ sudo testdisk /dev/sda
[Analyise]
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
1 * HPFS - NTFS 0 1 1 121600 254 63 1953520002
I backed up the partition with ddrescue
sudo ddrescue -r 3 /dev/sda1 ~/one-terra.img ~/log-1T-ddres.txt
Now checking the image with TestDisk gives me different structure details:
$ testdisk one-terra.img
Disk ~/one-terra.img - 1000 GB / 931 GiB
> 1 * Sys=72 13577 238 11 119521 238 60 1701990410
Bad relative sector.
2 * Sys=74 45381 70 3 79242 34 29 543974724
3 * NetWare 3.11+ 10498 56 41 10498 56 40 0
Retruning to the hard disk, I could fix the MBR but not the MFT:
[Advance][Boot sector recovery]
Status: OK
Status: Bad
Sectors are not identical.
..copied Bootsector over Backup boot sector.
..[Repair MFT]
How to proceed from here?
Re: Bad MFT, Trying on Image
It's a partition image, not a disk image, so the partition table type should be None, not PC/Intel.
In the Advanced menu, you may have to force the type to NTFS.
