Recovering "ghost" files?
orallo
#1 Post by orallo »
Hi all,
I've used photorec in the past to recover files from harddrives, pendrives, etc. I've never had a problem with it nor did I need support.
This time I'm trying to recover some photos from a hdd that its been sittin on a shelf for a long time and when I stored it was working properly now it cannot be mounted on windows.
Photorec sees the hdd conected, and starts the process. I've selected a folder called c:\recover to dump whatever photorec finds...
So far its veeeery slowly recovering some files, at least thats what the photorec screen says, but I cant find the files ANYWERE in my computer, not on the c:\recover folder or anywhere else for that matter...
Any ideas??
THanks in advance for your time.
Orallo.
I´m attaching a screenshot
remy
Re: Recovering "ghost" files?
#2 Post by remy »
You probabely have a defective disk (not far from the end, it can become very slow because of reading sector retries) and you should better image it and try a recovery on the clone. If it was in good condition before, you may perhaps be able to recover partitions with testdisk, instead of acrving it with PR.
EDIT : By the way, if you are looking for pictures only, select the file type you're looking for, unless you have some "ASCII pictures" in .txt files
orallo
#3 Post by orallo »
Thanks for your reply Remy,
But do you know where the recovered files went??? I cant find them anywhere on the computer.
Thanks,
-Orallo
#4 Post by Fiona »
If your OS is Vista/Win7 you shouldn't recover data in root (for example C:\temp).
Easlily try to recover your data into your profile /documents and create a folder there.
Standard path is testdisk folder.
Also check your Ownership.
In the background, there shouldn't run antivirus, norton ghost, norton sonar which can prevent data from recovery.
remy
#5 Post by remy »
Files are... where you told photorec to write ;)
You may find them by searching folders "recup_dir.*", or files f*.jpg with your search tool.
