Corrupted LVM partition - hard disk seems too small error?
avggeek
#1 Post by avggeek »
I had a LVM partition that became corrupted and fell out of the LVM array. The files on it are no longer visible when I use ls or any file manager - so I have not added it back to the LVM array.
I have tried scanning it using TestDisk but get the following messages:
Disk /dev/sdf1 - 2000 GB / 1863 GiB - CHS 243202 255 63
The harddisk (2000 GB / 1863 GiB) seems too small! (< 2010 GB / 1872 GiB)
No file found, filesystem may be damaged.
I am able to view the first level folders after Deep Search, but trying to view the contents does not work. I have cross checked against Gparted and it seems to confirm the Cylinder/Head/Sector information:
Gparted output:
file system: lvm2
partition table: msdos
heads: 255
sector: 63
cylinders: 243201
This is using TestDisk 6.13 on Ubuntu 12.04 LTS. Can anyone suggest how to proceed further?
Re: Corrupted LVM partition - hard disk seems too small erro
Can you run pvck on this partition ?
What is the result of "pvdisplay-a" ?
avggeek
#3 Post by avggeek »
Output of pvdisplay:
  --- Physical volume ---
  PV Name               /dev/sdf1
  VG Name               LCARS
  PV Size               1.82 TiB / not usable 16.00 MiB
  Allocatable           yes
  PE Size               16.00 MiB
  Total PE              119232
  Free PE               119232
  Allocated PE          0
  PV UUID               tELEcU-VREJ-HKdg-C6DZ-rtCv-GmvI-uK7vI5
Output of pvck -d -v:
    Scanning /dev/sdf1
  Found label on /dev/sdf1, sector 1, type=LVM2 001
  Found text metadata area: offset=4096, size=192512
    Found LVM2 metadata record at offset=6656, size=2048, offset2=0 size2=0
It looks good, continue with
vgscan -v
vgck -v
lvscan -v
avggeek
#5 Post by avggeek »
cgrenier wrote:It looks good, continue with
vgscan -v
vgck -v
lvscan -v
Output from the three commands:
 sudo vgscan -v
    Wiping cache of LVM-capable devices
    Wiping internal VG cache
  Reading all physical volumes.  This may take a while...
    Finding all volume groups
    Finding volume group "LCARS"
  Found volume group "LCARS" using metadata type lvm2
 sudo vgck -v
% sudo lvscan -v
    Finding all logical volumes
  ACTIVE            '/dev/LCARS/music' [200.00 GiB] inherit
  ACTIVE            '/dev/LCARS/movies' [1.10 TiB] inherit
  ACTIVE            '/dev/LCARS/amanda-holding' [200.00 GiB] inherit
Any suggestions on what I should be doing next?
#6 Post by cgrenier »
Run as root the fsck command against each device. You should be able to access this 3 volumes, try to mount them.
