Galaxy Note 2
zer01986
Galaxy Note 2
#1 Post by zer01986 »
Hi there, and its great to be here. Just need a quick from anyone although am not sure this falls under the right thread, i currently have a samsung galaxy note 2 which i think has disk problems in the internal storage. There seems to be a file in the internal storage labelled µOST.DIR which i cannot delete and it worries me because in the same storage is a file named LOST.DIR which i can find in another samsung device. therefore the µOST.DIR seems to be out of place. It worries me more that now some files that i deleted from my system (picture files) seem to resurface even after i delete the folders. Although they resurface the pictures are unreadable and seems to be corrupted. So only the folder and a list of all the corrupted files appear in my Gallery. Could this be a file system repair and if it is, is this software the right tool to fix it and if sum1 could show me how to get started i would love you so much more... Thanks.
