SD Card empty Topic is solved
yurff98
SD Card empty
#1 Post by yurff98 »
I had troubles with a quality SD Card 32 Go. It was almost full, then I try to delete almost the all of it, but it had an error in the middle.
Then I tried to use testdisk, it found a partition, but there was a problem with the boot system.
So I tried to rebuilt it, but didnt work.
Since then, it doesn't find the partition at all, even with deep search, so right now, i have no idea of what to do ?
I saw some options like geomertry and other stuff, but I really have no idea of what they are and how to use them, so I don't want to mess it up.
Somebody can help me ou ?
Thank you
Re: SD Card empty
If your goal is to recover your data, try PhotoRec http://www.cgsecurity.org/wiki/PhotoRec_Step_By_Step
If you want to reuse your card, delete the partition, create a new one and reformat it. If it failed, the card is probably damaged, use the warranty in this case to get a new one.
yurff98
Re: SD Card empty
#3 Post by yurff98 »
Thank you for the answer, and yes i will return hit cause it is impossible to do anything with it.
Even format is freezing my computer.
