I have troubles with my 32Go sd card.
It was almost full, so I try to delete the most of the files.
But there was a probleme in the middle.
Since then, I tried testdisk, it found the partition, but there was a problem with the boot sector. No way to use the backup of the boot system, so i tried to rebuild it. didn't work.
Now, testdisk doesn't see the partition at all, it s empty.
What should i do ?
sd card empty
